Discussing 24lb mass air flow sensor in the 94-95 Forum. may have my hands on one. how can it help me and what gains can ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
may have my hands on one. how can it help me and what gains can i expect?
#2 | |
Re: 24lb mass air flow sensor
1995 Mustang GT auto
13.81@101.6
The calibration of the MAF sensor must match the size of the injectors, otherwise the only thing you'll gain is a headache. A 24lb MAF together with 24lb injectors is a good mod to do once you're past the basic external bolt-ons and you're getting ready to do HCI mods. Don't forget to upgrade the stock 88lph fuel pump to a 190lph pump if you're staying naturally-aspirated, otherwise the 24lb injectors will be no use at all.
Ideally I think you should do 24lb MAF, 24lb injectors, and fuel pump upgrade in one go so if you don't have the money to buy all three yet, wait until you do. Otherwise, do the fuel pump first and the MAF/injectors later. If you're going forced induction or stroker, you'll need a 255lph pump and minimum 30lb injectors with matching MAF calibration and a computer tune. |
On Probation
Like said above, really wouldnt do anything unless you got some good bolt ons...It would just make your car (if stock) run rich, and could possibly be slower.
However, with the fuel pump, if you are going to replace it, i would not even bother with a 190lph, just go straight for the 255lph...The bigger pump doesnt hurt you in this case. |
good stuff people tnx. im told the 255 fuel pump is overkill, comments?
On Probation
I'm pretty sure getting a 255 isnt overkill because it is a return style system.
I know of people doing that before they do any mods anyway. What are your mods? |
#7 | ||
Chicken Plucker
1986 Mustang GT
Location: Smothering v606er with a plastic walmart bag in the back woods of Michigan
Yeah there is a return system you could get a 1000 lph fuel pump and still ge the same HP because whatever fuel the engine doesnt burn is sent back to the fuel tank
![]() 342 Stroker under construction |
Threads Similar to: 24lb mass air flow sensor
| mass air flow | arice | 94-95 | 2 | March 30th, 2007 12:12 AM |
| cobra mass air flow sensor | 02NEBstang | 99-04 | 3 | March 5th, 2007 08:39 AM |
| so what do i look for whrn getting a mass air flow sensor | gordon norris | 5.0 Mustangs | 5 | February 27th, 2007 03:07 AM |
| 24lb injectors + air mass meter? | 1990CA50 | 5.0 Mustangs | 4 | January 4th, 2007 10:42 PM |
| Cleaning the Mass Air Flow Sensor | IcantDo55 | 5.0 Mustangs | 10 | June 26th, 2006 12:20 PM |
