What Is Wrong With My Car?
Old November 8th, 2007, 09:13 PM   #1
94pacecarSVT's Avatar
11.2@122.36
94pacecarSVT is on a distinguished road
Send a message via AIM to 94pacecarSVT
ok i was missing bad during excelleration so i checked my injectors, rotor, coil, plugs, and wires. the coil was all messed up so i replaced it. then it go worse. it felt like i was on a derailing freight train. it was the roughest ride ever. everything on the car shook terribly. my plugs were fouled so i replaced em. they showed that i was running really rich. the car wont start right now. it has new plugs, which i put in yesterday, new coil which i put in sunday, new wires, and i changed the oil today, and made sure the battery was good. it turns over like it's tryin to start, but just wont. my next guess is either distributor, or computer. someone please help. thanks.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.
www.rk-collection.com
Old November 9th, 2007, 01:13 AM   #2
boss302_gt is on a distinguished road
+1 on the dizzy
Old November 9th, 2007, 07:11 AM   #3
11.2@122.36
if someone reads this and could help...please do. my car wont even start i have no way of getting it anywhere to be looked at. and i have no way to get to school or work. thanks.
Old November 9th, 2007, 02:32 PM   #4
Sounds like the internals of your distributor are fubar. In some cases theyll melt which in a couple trips will throw off the timing which would explain the fouled plugs. Now it might be in two pieces or so out of time that the car wont start. Pull the dizzy and see if the shaft can be easily rotated by hand. As long as you mark it with a scribe at the point where the two collars meet youll be able to put it back in with out throwing off your timing if that is not the problem. If youve never removed one before its a 1/2" bolt that holds it in place. Remove that and mark the collars. It pulls straight up and out but you have to turn it as you pull it. You stated that you changed the plugs and wires so Id also double check that they are in the right firing order just as a precaution. Hope others chime in with their diagnostics to help you out.
Old November 10th, 2007, 01:24 AM   #5
11.2@122.36
thanks for the help, i did accidently put my wires back on in the wrong order once, but i corrected it. im pretty sure its my times cause the plugs are firing, and the coil is brand new i just put a new one in last sunday night. but ill see, im gettin looked at monday, thanks again.
Old November 10th, 2007, 01:33 AM   #6
thenewGT350's Avatar
thenewGT350 is on a distinguished road
Send a message via Yahoo to thenewGT350
did you check all you ground points? I forgot to put that one little ground back on and it screws everthing up. you might want to have your computer checked out
Old November 10th, 2007, 02:03 AM   #7
11.2@122.36
yea i've thought about the computer, i just wanted to try everything else before i dumped the money in a new computer. but what exactly do you mean by grounds?
Old November 10th, 2007, 02:10 AM   #8
the ground wires that connect to the distributer, that would allow it to turn but not actually start, its really bad for the motor
Old November 10th, 2007, 02:11 AM   #9
and you probably shouldn't pay more than 80 bucks at a salvage yard for a computer
Old November 10th, 2007, 02:12 AM   #10
11.2@122.36
oh i see. i didnt mess with the distrubitor, i opened to cap and rotor to check it but couldnt get one of the bolts off the top of the dist. to get it out so i said screw it. lol
Old November 10th, 2007, 02:14 AM   #11
oh, I get it, yeah I had the same problem on a camaro once it took me all day to get it off
Threads Similar to: What Is Wrong With My Car?
You're Doing It Wrong... Onemanzu The Clubhouse 53 October 22nd, 2007 11:33 PM
Was I wrong??? JASonic The Clubhouse 32 October 18th, 2007 01:33 AM
something is wrong caintcatchmyGT 96-98 5 October 11th, 2007 11:14 PM
what else can go wrong? WAVEBYE The Clubhouse 17 January 29th, 2007 01:33 PM
Something wrong. Please HELP! Mikes88 5.0 Mustangs 3 October 23rd, 2006 09:49 PM
