302 Stoker Kit
Ford Racing Stroker Crankshaft Kits - JEGS
Is this kit a good kit for the 94 - 95 5.0 GTS? Will it make the 302 to a 347? Lastly, what kind of hp does this kit yield?
[quote=Speedstang302]nice...stallion...10...good job..only took you 20mins...not bad...Someone get out a camera...future post whore in the making..[/quote] [IMG]http://i46.photobucket.com/albums/f143/pwit/Randelman1.gif[/IMG] |
if you're wantin to stroke your 302 to a 347 then you need a 347 stroker kit. itll include pistons, rings, rods, and a crank. theres lots of good ones but jegs has one with forged crank and pistons and a i beam rods for $1059.99. thats the one im lookin at getting. and if you combine that with the right heads/cam/intake combination, bolt ons, and a good tune...you could make close to 450 at the ground. thats what im wanting to do to my 94 cobra.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
just stroking without the supporting mods or without matching it with a good HCI combo is not gonna get you an insane amount of power...im pretty sure that its just the difference in the numbers 347-302= 45hp. i could be wrong but i know i have heard that somewhere.
![]() 95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete BOOSTED |
#5 | |
i have looked at those and i'm deff. interested in the 347 kit. do you know him personally or somethin?
#7 | |
+1, as soon as i get away from this money trap that we call COLLEGE, i am having Jim build me a motor as well...I have spoken with him on here and on SBFTech, GREAT guy!
#9 | |
Darrell / Anthony, good stuff, looks like an affordable kit too! Whats the install time on something like that and will I need anything else to get the kit installed properly?
#10 | |
you NEED a good h/c/i with a larger displacement engine.
I wouldnt run any heads that are smaller than 180cc. depending on what you plan to use the engie for... you might even wanna consider a set of canfield 195'x, RHS 200's, AFR 205's... etc As for a cam... custom grind is the ONLY way to go.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
#12 | |
Custom cams are not the ONLY way to go. Plenty of off the shelf sticks will get the job done if 400-450hp is your goal. Heck, even 500hp. With a 347, i wouldnt use anything smaller than a 170cc head if its a dedicated street engine.
#13 | |
If it came down to a choice between heads, cam and intake or a 347 kit I would definitely do the heads, cam and intake. Heads will bolt on more power than any other engine component. More cubic inches will need a better cylinder head to keep up with the increased cylinder volume. Internal combustion engines are nothing more than air pumps. More air in, more air out equals more horsepower.
#14 | |
1988 Mustang Notch
it's a bad bitch..i promise
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
#15 | |
1995 vert. x-mod
na
Scat makes a GREAT stroker kit Also, u ask any engine shop, there cranks are some of the best out of the box. What block r u using?
JASON ERIC BRESMON 1979-2004 TILL WE RIDE AGAIN A candle that burns twice as bright - lasts half as long |
1994 Mustang GT
good luck with your choice!
![]() powered by : Forged Internal 347 Stroker Motor with AFR heads, 3.73 gears, Built 4R70W, and 150 hp Nitrous Works Wet Kit. No times yet but coming soon..... ![]() 1994 Ford Mustang GT 1997 Ford Expedition XLT 4X4- Mustang Tow Vehicle 2003 Yamaha R1 |
who built ur motor N20STANG347?
1994 Mustang GT
AMP Performance located in Arizona. I could have built a motor but I was afraid to have a catastrophic failure and not have a warranty. I had a co worker that had built an engine for his 03 Lightning and a few months later his engine blew up on the dyno and he lost nearly 8-10k on the engine. Nothing hurts your pride like that especially if your name is on it.
Threads Similar to: 302 Stoker Kit
| STOKER!!!!!!!!!!!!!! | kreil45 | 5.0 Mustangs | 14 | October 6th, 2007 09:06 PM |
| 331 stoker kit | gtstang87 | 5.0 Mustangs | 8 | June 1st, 2007 12:47 AM |
| stoker kit | noturnormalv6 | V6 Mustangs | 8 | January 18th, 2007 12:43 PM |
