#21 |
95 Mustang GT
Yep just changed my order.....alan at dirty dog talked me into the ford racings....yep yep
#22 |
whats up with those "top end kits" from late model restoration? i have the catalog and it only has the kits for the 79'-93' mustangs. but would they fit my car?
#23 |
![]() iTrader: 1 reviews
Yeah it will fix your car, providing it's a 5.0 the ony difference is mostly the TB to the Intake manifold. There's an elbow that Trickflow sells to connect the Intake to your TB.
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
#24 |
90&94 GTs; 79&91 Broncos
I'll chime in on the gears-just because I have something different to say than most everyone else on that matter.
I did 3.73s in the wife's 94GT w/auto. I don't regret NOT going 4.10s because I can cruise 80, still be under 2500rpm, and it is MUCH better to drive around town than 2.73s. I put FMS gears in because they came on a 31spline t-loc I put in the Bronco. If I were to order gears I would go with Yukon-that's what I put in the Bronco. I put 4.10 Yukon gears in and I was able to use the factory pinion shim and carrier shims. I got an excellent pattern with no gear noise. I had Richmond 3.55s in my 90GT before--talk about whine! Go to Randy's Ring & Pinion and have a look around. Their install kits are second to none--even better than FMS! Their super-shims are really easy to work with-alot better than messing around with flimsy .010" shims by themselves. In the end it's up to you on what you want to do with your car--Randy's has a gear ratio/rpm calculator to help you figure out what you want to put in the rearend. |
Threads Similar to: 94 GT Mods
| 2.3T Mods | Ga_50_foxbody | 2.3 Mustangs | 55 | July 11th, 2007 01:56 PM |
| mods?? | mb03stang | 99-04 | 6 | July 6th, 2007 02:30 AM |
| mods | 06dkkiser | V6 Mustangs | 10 | June 26th, 2007 07:44 PM |
| mods | Mustang RacR94 | V6 Mustangs | 5 | March 30th, 2007 05:23 PM |
| 07 top 5 mods for under 400$ | TDog | 2005 - 2010 | 22 | February 9th, 2007 10:39 PM |
