Axle Damper Shocks
Old November 17th, 2007, 09:55 AM   #1
TIM350 is on a distinguished road
Axle Damper Shocks
So I finally replaced these two shocks in the rear after a year of having the mustang. When I bought, one was broken and the other was completely worn out. (206,000 miles on it) I originally just replaced the u/l control arms with the bbk u/l and noticed a lot firmer launch. I know alot of people tell you you do not need the quadra shocks when you have aftermarket control arms but you absolutely need then b/c my mustang grips the road alot better now and is also less harsh when the rear hits a bump. Definitely worth the $85 investment.
Old November 18th, 2007, 12:47 AM   #2
Levon is on a distinguished road
I did the same upgrade on my sn95, bbk u/l control arms. Which brand of quads did you go with? I have yet to drive my stang and am anxious to feel the results of my upgrades. I have a list of mods to install. My second quetion is which kind of grease did you use to grease the certs on the u/l control arms
Old November 18th, 2007, 08:56 AM   #3
I used the cheap kyb's from advance auto. I got my brother discount so without that they would have been $50 +tax each. I used the lube that came with my bushing kit for the install and about every two months after the install I hit it with the red bearing grease I have laying around thats made for Ford.
Threads Similar to: Axle Damper Shocks
i need shocks!!! droppedbass87 96-98 23 September 16th, 2007 04:17 AM
28 OZ DAMPER AND FLYWHEEL NEEDED ken5_0 5.0 Mustangs 8 April 6th, 2007 04:37 PM
FLUID DAMPER ken5_0 5.0 Mustangs 4 March 19th, 2007 08:39 PM
Differences between normal Shocks and Digressive shocks Mustang68 General Tech 6 March 11th, 2007 12:44 PM
