1995 Mustang 232ci 3.8L
1995 351 to swap or not to swap.& how to?
i have 95 v6 and i would one day like to build my favorite saleen the 95 s351 well i have the 2 main components but dont know if ican use the motor. my friend gave me a 351 that he took apart at the school shop a year ago. i picked it up today only to find that im missing a piston the rocker arms and pushrods. those can be replaced what i need to know is if the motor is worth rebuilding bc theres rust on the block and heads. also the motor came from a boat that was prob used in saltwater.
1995 Mustang V6 232ci 3.8L EFI Flowmaster Dual exhaust w/ H-pipe,and no cats. k&n airfilter. yep thats it, im too broke to do anything else
![]() iTrader: 1 reviews
I do believe you will have the block clean up polish the heads to get some good flow. If you can strok it to a 393 and get a stroker kit. I have a set of trick flow rockers arms and pushrods BRAND NEW never used also if your interested.
I have a Ford 351W Block from a boat also. I'll like to know
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
the surface rust wont hurt it a bit if you have a shop clean it up and do work on it... id do that anyways.
id say check for cracks and leaks.
what kind of trans do you plan on using?If you plan on doing a stroker you should install aftermarket heads,cam and intake so you can take advantage of those cubes.351 strokers come with alot of choices of cubes,377,383,393,408,and418.if you plan on adding forced induction to that 351 look into forged pistons and good rods like Scat
88 GT
Location: Somewhere among the vast frozen wastes that is Alaska
I'd say go for it, the marine blocks were a bit heavier than the automotive ones but the extra strength more than makes up for it.
I'd rather go fast than look good, cause goin' fast IS lookin' good. |
1996 Saleen S351
There is no difference in the marine block and a production block. The only difference is in the year models. 71-74 blocks have a little stronger main webbing. After that they are the same. Only change was in 94 they made the lifter bosses taller for roller lifters. They did offer a mexican 351w block that was used in marine applications. It is identical to the 71-74 block except it has an extra boss cast in the side of it for a mount. It sonic checks the same as a 71 block. Weighs the same too.
To do the swap you will need the wiring harness and computer from a 94-95 GT. |
#9 | |
1995 Mustang GT
if it was in fact a marine motor, you need to find out if it was run in salt water or not. if it was, STAY AWAY from it. there will be corrosion in there that you can't see and will give you all kinds of hell down the road. even though it may be true that marine blocks are a bit stronger, i wouldn't go near putting one in my car - my family owns a marina, and i've seen what salt water can do. trash that and find a good 351 block somewhere else
Threads Similar to: 1995 351 to swap or not to swap.& how to?
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 05:33 PM |
| 1995 3.8L V6 swap to 5.0L V8 | nikbait | V6 Mustangs | 11 | March 18th, 2010 10:48 PM |
| 1995 3.8L V6 swap to 5.0L V8 | nikbait | 5.0 Mustangs | 11 | July 5th, 2008 06:04 PM |
| 351 cleveland into 1995 v6 swap | MattKG85 | Modular Mustangs | 0 | September 13th, 2007 05:23 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
