Discussing High Temp in the 94-95 Forum. okay guys, this friggin problem has been driving me nuts for about a month now. ...
Old August 30th, 2006, 04:29 AM   #1
High Temp
okay guys, this friggin problem has been driving me nuts for about a month now. after about 4 to 5 miles of driving my temp gauge climbs to the "L" on NORMAL. if i have my a/c on, it stays there. if i have my a/c off it drops to about the end of the "M". i have had my radiator rotted out, new end tanks put on, a new overflow reservoir put on, my block power flushed, a new thermostat, a new radiator cap, and nothing seems to help. i also tried burping the system a couple of times. does anyone have any more ideas??????????
Old August 30th, 2006, 09:36 AM   #2
2001 Mustang Cobra
heat
I had a similar problem. I ended up getting two thermostats, the first one I bought was crapped out right out of the box. But it sounds like there is air in the system. I have this in my 01 Cobra when I redo the system.
john
Old January 20th, 2007, 02:44 PM   #3
I know this is an old posting, but i gotta tell you I had the same problem and sovled it with a new temp sensor. Darn 5 dollar part. Then about two years later my temp gage would never go over the "N" in "NORMAL". Everything else checked out ok, turned out once again to be the temp sensor. Guess they just don't last very long.
Bert
Old January 21st, 2007, 12:21 AM   #4
yeah the stock unit is junk...i have an autometer and a stock and the difference sometimes is crazy
1995 GT::Sold!
Looking for another stang...
Old January 23rd, 2007, 01:39 PM   #5
If you try a new temp sensor and that doesnt work, take it to a decent shop and tell them that you want the coolant system vacuumed down. Not to vacuum out the existing coolant, but to vacuum it down to remove all of the air. There is a tool that vacuums down the system and then when you reopen the vacuum valve you can suck fresh coolant right into the system.
Threads Similar to: High Temp
temp guage sivart 5.0 Mustangs 10 July 11th, 2007 07:37 PM
new temp gauge burnout5.0 94-95 3 July 6th, 2007 05:10 AM
HIGH TEMP. black95conv 94-95 2 June 30th, 2007 08:35 AM
temp indication dcraig8 5.0 Mustangs 1 August 18th, 2006 11:08 PM
studder and high temp dcraig8 5.0 Mustangs 1 July 25th, 2006 12:00 PM
