How Do I Know If My Rears Got The Gears?
i have a 95 mustang gt and it might have 4:10s but i have no idea..i was hoping that someone out there has a 95 gt with 4:10s and can give me a couple mph with rpm readings....
¡ʇsnq ɹo uʍop ǝpısdn
give me some rep points and i can get you a gear calculator so you can write down your own numbers and formulate your own ideas
#3 | |
Big timin' in a small town
And he will give it to me if anyone
Gear Comparison
![]() have fun use the right tranny and plug in some of your own numbers and see if anything lines up ... note that these are therotical numbers and might be off by a small amount due to wear tear and other variables... such as friction temperature and altitude...
You will run about 3100 RPMs at 80 in 5th gear
I gave you rep OMZ now give me more.
OMZ you havent returned rep yet
Oh shit well fuck. I wated ssome on you then your at 91 now
what are rep points and how do i get them so i can give them to you.
95 Mustang GT
there was a thread about this the other day....not sure but someone can tell you....you turn the wheel and count how many turns it takes to turn the drive shaft 1 revolution or something .....and then some equation.....good luck bro....do you have a lot done to the car...if its pretty much stock I highly doubt someone went as low as 4:10's but never know ....good luck and welcome
yea well i bought it with a cam,1.7 rockers,headers full exahust,short shifter,frame supporters,70mm tb,and more...
#15 | |
see the green bar under your name? that's your reputation. now click the scale under your name. it will tell you how many rep points you have. if you click someone else's scale you have the choice to leave either positive or neg. rep.
1990 Mustang gt
Lift the rear of the car off the ground to where you can easily see the driveshaft. Now make a reference point on the wheel/tire and on the driveshaft. Turn the wheel 1 full turn and count the # of times the driveshaft spins. If its just over 4 turns then it has 4:10's.
2002 gt 5-speed 1990 gt 5-speed 1981 Notch Roller |
Threads Similar to: How Do I Know If My Rears Got The Gears?
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005 - 2010 | 91 | November 11th, 2007 01:25 AM |
| Rears are done! | Ole Yeller | V6 Mustangs | 5 | July 9th, 2007 08:32 AM |
| 3.73 gears | cali 5.0 | Modular Mustangs | 8 | April 20th, 2007 09:58 AM |
| gears?? | jat | 2005 - 2010 | 7 | April 13th, 2007 10:15 PM |
| what is the favorite gear-oil for limited slip rears | cobraetti | 5.0 Mustangs | 0 | January 20th, 2007 07:19 PM |
