Clunk In My Rear
i have a 94 gt with bbk springs and lower control arms. the problem is i hear i clunk in the rear when i hit a bump at an angle. i look everything over but didnt see anything loose or busted like a bushing or anything. so any help would be great thanks
1999 Ford Mustang V6
did you try checking the torque of your control arm bolts?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
no not yet. just gave them a look to see what i could see.
it's your bump stop. its above the rear end directly above the pumpkin. you can either remove it all together or remove it and trim some off and put it back. its just doing its job. its to keep the body from bottoming out and smacking the suspension or the ground if you hit a really big bump with stock suspension. i lowered my 96gt and had the same problem i just removed it all together. it's only like 4 bolts.
you might be able to get away with just putting a glob of grease on it.
is your exhaust hitting my GT is lowered and the exhaust is hitting the swaybar so I get new exhaust!!
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
did you put the pads back on the springs when you installed them...if you did not, this will certainly make some noise over bumps
Previous and Current Rides: 1967 Ford Mustang Coupe 2002 Ford Mustang GT--SOLD! 1967 Ford Fairlane 500 XL--SOLD! 2003 Ford Mustang Cobra 1 of 308--SOLD!! 2003 Kawasaki Mean Streak--SOLD!! 2006 Harley Davidson Screamin' Eagle V-Rod |
Threads Similar to: Clunk In My Rear
| Great...clunk in the rear pass. side | twok3gt | 99-04 | 2 | October 14th, 2007 03:53 PM |
| clunk noise | Murderjetz | V6 Mustangs | 20 | March 28th, 2007 10:59 PM |
| Rear End Clunk | 01Pooter | 99-04 | 16 | December 20th, 2006 10:09 PM |
| Clunk! | MustangGTNY | 5.0 Mustangs | 1 | October 26th, 2006 10:25 PM |
| Still Have A Clunk In My Rear End | militarygt | General Tech | 7 | October 9th, 2006 05:47 PM |
