Not Sure What To Do Next
I have u/d pulleys cai bbk off road x flowmaster 40s 3.73 tri ax shifter ford racin drive shaft not sure what to do next I think i might try and find a junked explorer and take the intake but should i get a new tb before and if so what size 65? or should i do bigger injectors and cam Im kinda stuck and not suree what to do now I dont have the money to go buy the system max kit I want and dont want to see if my motor can handle nitrous
well, the first thing you gotta do before anything is beef up your suspension, because without traction, YOU AIN'T GOIN' NOWHERE. So i would recommend some upper and lower rear control arms, maybe some subframe connectors, a panhard bar, and swaybars or something to get you going. Then maybe a new ignition, because i have heard of people finding power that way, and play with the timing a little, you could pick up some easy hp with that. And finally, go get it dyno tuned. Not just dyno'd but TUNED. Because if you have a good tuner who can burn you a chip, it not only can gain you power but it can be SMOOTHER too, which really does help. Other than that maybe heads and a stroker kit.
![]() 2009 Highland Green Bullitt #5998 1994 Rio Red SVT Cobra #320 SOLD 2007 Tungsten Mustang GT |
Don't be afraid of the bottle !!!!
I ran 150 dry shot on a 95 gt with 140k on the stock engine( ok, cold air only ). Abused it for 2 years and had no issues . You can even ping the engine with a dry kit to find the exact timing without worry of damage unlike with a wet kit. But I agree with 94cobra320...Dyno Tune is the way to go, just expensive...
www.freeautomechanic.com |
In my personal oppinion I would go with a stroker kit and stay away from nitrous. I have a 95 vert with a 347 stroker and I love the hell out of it. It is really your choice but, I think that nitrous is cheaters gas. You cant make real power so you have to feed it an energy drink.
![]() iTrader: 1 reviews
cheaper gas that makes you go faster.... lol
j/k but yeah real power is the way to go
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
I would say go next for a camshaft & intake.. ignition? maybe MSD billet distributor, blaster coil & 6AL box, if you like.
Intake: Lots of 'em in the market for stock EFI motors: Edelbrock Performer 5.0 - or Performer RPM for strokers & nitrous, TFS EFI Street Heat - or Track Heat for strokers & nitrous, and the famous Holley Systemax II. If budget is an issue, get Explorer intake that flows better than Saleen - check this link: AFM: Explorer Intake Install Check out those long runners on the upper manifold of Explorer intake. This WILL give you a huge increase in the low end torque that will shred your tires with those 3.73's you got! The lower intake is a Cobra GT40. Camshaft: Ford Racing E303 is the most popular camsahft for stock motors, I also like TrickFlowSpecialties Stage 1 camshaft for 302 SBF. Edelbrock got one too, that goes with their intake & head combo. And you will need a 70 mm TB with the above. Now you can beef up your chassis & suspension. |
euro eater, about the 347 stroker.... i am debating on whether or not to go 347 as well, what kind of HP are u making? are u still fuel injected or did u swap tp carb? what about stroker kit, heads, manifolds, cam.... srry for all the questions....
You dont have to appologize I am happy to answer your questions, First off for hp and torque, I am making 289.32 hp and 338.36 ft/lbs at the rear wheels. Keep in mind that this is at 6000 feet above sea level and it is all motor. Yes I am still running fuel injection. I have a custom cam for a blower, which I dont have one at the moment. I have a Trickflow Track Heat Upper and Lower Intake, Trickflow Twisted Wedge Heads, the stroker kit was bought from Coast High Performance, the website is www.coasthigh.com. I had my builder assemble and do the machine work. The engine costed me around 5,200 for a long block, but it is a Dart Block with machine work, rotating assembly, and heads. My dyno guy thought that with a vortech s trim system it would make around 550hp and 700ft/lbs at the wheels. What I am getting at is if you have a solid foundation, it is easy to make lots of power down the road. I hope I was helpful.
For a prepped Dart block with TFS heads & intake plus forged CHP 347 kit, $5200 is a very good price, but I think you should be making more power with that spectacular combo.. something around 380 rwhp, dont you think?
Well I thought so to, but I was thinking it is because of the custom cam being set up for a blower, I could be wrong.
I thought so.
Cam selection makes huge differences. In my case, I was using a N/A cam in a blower application, and it was a disaster. Had to work it out all over again, and it's going in progress. |
