Starter solenoid clicks at the starter but wont start the car??
LinkBack (8) Thread Tools
Old January 13th, 2008, 08:24 PM   8 links from elsewhere to this Post. Click to view. #1
95StangSVT's Avatar
95StangSVT is on a distinguished road
So here's my problem 3 months ago i went to leave work and when i started my car i just heard a bunch of clicking so i assumed it to be a bad battery connection,i checked them all and everything seemed right after it wouldnt start i know it was the starter so i kept trying to start it till finally the started kicked over and it fired up,i drove it home pulled the starter out put a new one in and everything has been fine since for the last 3 months, Well till i got to my brother inlaws house friday night where it started just clicking again at the solenoid,once again checked connections all good ,pushed started the car got it home pulled the starter ,got a new one and tested it to make sure the new one was good installed it and its still clicking at the solenoid but not engaging to turn the fly wheel??????im lost is there something else that could be bad?i put and had tested two brand new starters and it still just clicks away...
Race you for your lady!!!!!!
95 Stang Svt
02 Suzuki GSXR
95 Nissan Hardbody Minitruck (Bagged)
04 Suzuki LTZ400 Quad sport
Old January 18th, 2008, 01:40 AM   #2
problemCOBRA94's Avatar
1994 Mustang Cobra
it runs now. Kinda...
problemCOBRA94 is on a distinguished road
Send a message via Yahoo to problemCOBRA94
check the "in line spout connector"
I know what I am talking about. some where near the battery there should be a little single black wire that has a quick disconnect style harness connector. That is what grounds the ignition. the solenoid will click but the starter wont turn. I sounds like the starter is wedged in place but it's not.
That should fix the problem.
mine kept coming apart so I pulled the two black harness housings off the wires. (they slipped right off) then I put the wire ends together and just pinched them with a set of pliers, then wrapped them in tape.
Old January 18th, 2008, 02:55 AM   #3
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
Clean your battery terminals..... then report back Its hard to tell without being there with a DVOM but this is the #1 cause.
TT Build in progress.......
Old January 21st, 2008, 05:50 PM   #4
95StangSVT's Avatar
diffently not the battery there clean but u cleaned them again for good measures lol,havent located that black wire yet,i need to get down there with a test light and see if its getting ground and power
95 Stang Svt
02 Suzuki GSXR
Old May 29th, 2009, 09:10 PM   #5
95BlackStang's Avatar
2000 mustang GT
95BlackStang will become famous soon enough
did you ever fix your problem?
im having the same problem right now, i cleaned the batt and the sileniod only clicks once, putt my dads batt in it and nothing.
00 GT with the heart of a green machine!
99 Electric Green GT R.I.P.
95 GT vert....my first love sold!
Originally Posted by BaznastyDave View Post
99-01 Cobra bumper with Mach spoiler and make all the girls panties wet.
Old May 30th, 2009, 12:21 AM   #6
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
auto or manual, solenoid will be on your firewall, take a razor with a handle or a screwdriver and jump it and should start right up, ive had them go out before (bad ground not really go out) where they just keep clicking or wont click at all
Ford mustang solenoid image by stangman16 on Photobucket
right across them 2 studs
www.moddedmustangs.com
Old May 30th, 2009, 02:02 AM   #7
2000 mustang GT
thanks man much appreciated , now all i have to do is go get my car from the shop at work
Old May 30th, 2009, 03:05 PM   #8
2000 mustang GT
ok so i dont know what might be the problem. when i go to start the car all it does is just do one click, i checked all fuses and they are good, i did the jumper thing with a srew driver and all it does is spin the stater it sounds like its not engaging the flywheel, i thought it was the starter so i changed it, nope it still just spins. im at a stand still from here. can any one help me!
Old May 30th, 2009, 06:17 PM   #9
Lind's Avatar
have you tried putting in a new solenoid? if not try that and when putting the wires back on the new one make sure you take a wire brush or sand paper and clean them up real good
Old May 30th, 2009, 08:56 PM   #10
2000 mustang GT
yeah i put a new starter in it, i think i know what the problem is, the starter engages but the engine wont turn over it just clicks, im thinking its the battery at this point, im check and charge it all night and see what happens tomorrow
Old May 31st, 2009, 12:32 PM   #11
2000 mustang GT
ok so i let it charge all night and it still just clicks and then locks up. i also took the cover that covers the clutch fork and had a friend try and start it and it berly moves like 1/2" and then gets stuck. i have no idea what to do from this point.
Old January 14th, 2010, 09:07 PM   #12
jayfizz24 is on a distinguished road
I have the same problem and i don't know what to do. 95 blackstang did you ever get yoour started if so what did you do. I have a 2000 gt
Old March 10th, 2010, 10:56 PM   #13
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
koessl will become famous soon enoughkoessl will become famous soon enough
has this been solved? Same issue here.
Military Crew
Completely stock... I promise.
Old March 11th, 2010, 11:22 PM   #14
2000 mustang GT
yup this it worst than i thought!!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/50643-starter-solenoid-clicks-starter-but-wont-start-car.html
Starter solenoid clicks at the starter but wont start the car?? This thread Refback September 21st, 2011 01:09 PM
93 Regal won't start, clicks, full charge, terminals clean This thread Refback August 22nd, 2011 08:24 PM
93 Regal won't start, clicks, full charge, terminals clean This thread Refback April 21st, 2011 04:10 PM
93 Regal won't start, clicks, full charge, terminals clean This thread Refback April 1st, 2011 12:53 PM
No Start, Rapid Clicking at Solenoid - International Full Size Jeep Association This thread Refback July 12th, 2010 09:02 PM
93 Regal won't start, clicks, full charge, terminals clean This thread Refback June 20th, 2010 01:13 PM
93 Regal won't start, clicks, full charge, terminals clean This thread Refback January 26th, 2010 12:26 PM
Starter Solenoid Click on Kosmix This thread Refback April 25th, 2009 09:30 AM
Threads Similar to: Starter solenoid clicks at the starter but wont start the car??
How can u tell if its the starter or the solenoid? noyz25 5.0 Mustangs 11 October 28th, 2007 10:48 AM
Starter/solenoid problem WIKD 2.3 Mustangs 2 October 4th, 2007 08:15 PM
starter solenoid question fastford3388 5.0 Mustangs 2 April 23rd, 2007 11:40 PM
Starter solenoid? 8A_Honda 5.0 Mustangs 9 March 13th, 2007 01:23 AM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 07:34 PM
