Discussing freeze plugs? in the 94-95 Forum. how hard are they to replace with the engine in the car?...
Old January 15th, 2008, 02:50 PM   #1
94pacecarSVT's Avatar
11.2@122.36
freeze plugs?
black 96 gt w/ 00 gt motor, procharger p1sc 11lbs intercooled. comp cams xe274h .500 lift, full bolt ons, full tubular/alum. susp. w/ coil overs. 4 pt. roll cage. more pic and full list of mods in garage.
www.rk-collection.com
Old January 15th, 2008, 03:32 PM   #2
1966 Mustero
12.50
Some are hard some are easy
Old January 15th, 2008, 04:18 PM   #3
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
They make a temporary rubber plug that tightens up and expands. That will get you buy for a while. Why do you have to replace freeze plugs?
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old January 16th, 2008, 09:03 AM   #4
11.2@122.36
well, i think (and hope) its a freeze plug. i have a coolant leak and its on the drivers left side of the engine. the car overheats pretty quickly when i drive and it steams and boils and coolant leaks out in an almost steady flow. my only three guesses were that it was a freeze plug, head gasket, or a cracked water journal. if its a cracked water journal then im just gonna say fuck it cause i cant afford to fix that. even welding it would require the engine being taken out of the car. and a new block after the machining and all is said and done would be a few grand. so idk help is appreciated.
Old January 16th, 2008, 04:22 PM   #5
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
If you pop a freeze plug it is usually something major that causes it. I would lean more toward a bad gasket or hose.
Old January 17th, 2008, 11:41 AM   #6
11.2@122.36
i took a better look and found that its leaking out at the timing plate cover.
Old January 17th, 2008, 03:07 PM   #7
flamedstang95's Avatar
1995 Mustang GT
It wouldn't hurt to change your coolant temp sensor either. Freeze plugs don't usually have to be replaced.
See garage for mods
Threads Similar to: freeze plugs?
PSP computer freeze White Thunder The Clubhouse 14 January 1st, 2008 06:51 PM
anyone running mr freeze? shoebox1.1 Drag 3 July 18th, 2007 11:37 AM
Mr. Freeze Wally1968 2005+ 11 June 12th, 2007 02:32 AM
Help With Anti-Freeze Leak super96mustang 96-98 7 March 21st, 2007 11:56 AM
so i just found out i can pour anti freeze down my toilet Onemanzu V6 Mustangs 12 January 5th, 2007 02:26 AM
