throw-out bearing
Old January 22nd, 2008, 01:19 AM   #1
white50 is on a distinguished road
throw-out bearing
i have this annoying whistle coming from the transmission. and it goes away if i simply rest my foot on the clutch pedal, keeping it from engaging but just barely applying pressure. now its louder. i was told that it was the throw out bearing. what would i need to go buy in order do replace te throw-out bearing. is there a kit that includes everything or what
thx guys
Old January 22nd, 2008, 01:30 AM   #2
also.. i have a king cobra stage 2 clutch.. dont know if that makes a difference or not..
Old January 22nd, 2008, 01:32 AM   #3
robuilt is on a distinguished road
I had the same problem so I went ahead and bought a clutch kit to just swap it all out since I was already tearing it down.
I went with a zoom clutch from summit racing. I have a buddy running high 11s in his 5speed with the exact same clutch.
Paid about 130 for it....t/o bearing and all
Old January 22nd, 2008, 01:44 AM   #4
well if ive already got a clutch then what else should i get to "beef" up the tranny
Old January 22nd, 2008, 01:53 AM   #5
91cobra5.0's Avatar
94 GT
the through-out bearing is the one that the clutch fork rests on right? well i just did my clutch and changed it all out. i had some whistiling coming from the clutch area too but i thought mine was more of the piolet bearing, when i did pull it all out i noticed tho that both bearings were goin bad, the through out bearing had some play and the piolet bearing broke on the process of getting it out. and as far as i know there is no kit
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old January 22nd, 2008, 01:54 AM   #6
91cobra5.0's Avatar
94 GT
id just buy the clutch and new bearings, u shouldnt have 2 worry about the fork
Old January 22nd, 2008, 03:04 AM   #7
so how much does an afermarket clutch go for then.. if the clutch is good then why replace it is my question..cause the clutch is new
Old January 22nd, 2008, 04:05 PM   #8
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
If your clutch and pressure plate are new then leave them on there. You can order a TO bearing from Atomic Performance - TA Performance, Pro 5.0, SCT, C&L, JLT Cold Air Give them a call and ask for Jeff Z. The centerforce piece is 34.95, free shipping, and will be to your house within a day or two. You'll have to pull the exhaust, driveshaft, tranny mount, and finally the tranny. There's nothing you can really do to "beef" up your tranny unless you have it rebuilt. You could add an aluminum flywheel if you've got the money but it isn't necessary. Good luck!
See garage for mods
Old January 22nd, 2008, 06:17 PM   #9
well my clutch was going bad too so i just bought a new one, Zoom Clutch from Summit racing, $130.00
Old January 24th, 2008, 12:15 PM   #10
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
Sounds like a throw-out bearing to me. I had mine whining and i had plans to go to the track with my bike but my bike broke so i took my mustang with plans to break it because it was pissing me off. sure enough, second run when i shifted into second i heard a lot of clanking and my throw-out bearing ended up at the bottom of my bellhousing. I'm sure thats not something that you want. I had to drive home from the track in 5th gear not fun.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Old February 11th, 2008, 06:50 PM   #11
Look Ma! My First Post!
1987Rock is on a distinguished road
I've got the same problem. I've had the car 2 months and the guy before me just put a new t/o bearing in, but the shaft it rides on is scored, so that's making the noise. So make sure to check the shaft too.
Old February 12th, 2008, 02:50 PM   #12
1995 Mustang GT
the shaft that you speak of is called a bearing retainer. You can buy them from summit or jegs for around 40 bucks. Make sure you get the one for 94/95's because they are 5/8 inch longer than fox bearing retainers.
See garage for mods
Threads Similar to: throw-out bearing
throw out bearing 40thmustanggt 99-04 2 August 8th, 2007 07:45 PM
Throw Out Bearing KMast14 V6 Mustangs 17 August 6th, 2007 07:43 PM
throw out bearing already???? 40thmustanggt 99-04 12 July 9th, 2007 10:26 PM
help! faulty throw-out bearing stang2000 Modular Mustangs 1 January 11th, 2007 11:40 PM
