BBK Intake Manifold
Old October 17th, 2006, 06:43 PM   #1
lugthug713's Avatar
lugthug713 is an unknown quantity at this point
BBK Intake Manifold
Hey I was wondering if anyone know if the BBK intake manifold with fit the 94-95 stang. I am thinking it will you just need a cal. hood. Anyone know for sure? I have the trick flow intake manifold anyone know which one is better I was going to change it out to the BBK.Whats you opinion
Old October 17th, 2006, 06:52 PM   #2
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
which trick flow manifold do you have? i'm sure it is better than a BBK.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old October 17th, 2006, 07:20 PM   #3
lugthug713's Avatar
I have the
trick flow Intake Manifold, Street EFI
Old October 17th, 2006, 07:22 PM   #4
lugthug713's Avatar
and I was wanting to go to this BBK
Old October 17th, 2006, 08:32 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
BBK=junk
Old October 18th, 2006, 12:05 AM   #6
I have no experience with the BBK manifolds but what I have heard about them is exactly what darrel said. That trick flow manifold is really good for your application from which I am guessing you still have the 302. If you have a 302 based stroker then I would suggest going to the track heat manifold depending on what heads and cam you are using.
95 Mustang GT
Slow Bolt On Car
Old October 18th, 2006, 12:38 AM   #7
Zak
Zak is on a distinguished road
Yeah.. You're probably going after the looks!
TFS, Edelbrock & Holley make the best intake manifolds.. better than FRPP
BBK, Professional Products and others only look good...
Old October 20th, 2006, 12:34 AM   #8
lugthug713's Avatar
Gotch ya BBK=JUNK thanks!!!
Old October 20th, 2006, 12:40 PM   #9
HORSMEN1995 is on a distinguished road
i would go with Trick Flow, but thats just me
Old October 31st, 2006, 09:01 AM   #10
Zak
Thought you should know.. but I have December 2004 issue of 5.0 Mustangs & Super Fords magazine.. page 53 under the title Stage Fight:
Test Car:
'93 Cobra hatchback
306 short block with stock cam, stock computer, stock 24# injectors
Pro-M mass airflow meter
Edelbrock Performer RPM heads 2.02x1.60
1-5/8" full length headers, H-pipe & smog pump eliminator
Results:
With Stock Intake: 233 rwhp @ 4850 rpm, 289 ft.lb @ 3600 rpm
With BBK SSI Intake: 265 rwhp @ 5100 rpm, 296 ft.lb @ 4100
so that's a total of 32 horses at the rear wheels, at a higher RPM band
Old October 31st, 2006, 10:06 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Test Car:
'93 Cobra hatchback
Results:
Quit focusing on peak power. How much power did it lose across the mid range? You can make more peak HP and go slower..... Don't always believe what comes out of magazines either. A wise racer once said "those who don't read automotive magazines are uninformed, those that do read automotive magazines are misinformed".
Read this article and tell me if you still think the BBK intake is better and then tell me why you think that way.
http://www.compcams.com/Community/Ar...p?ID=611023281
Old October 31st, 2006, 12:36 PM   #12
Zak
I didn't get it Darell
I didnt say that BBK is better than anything, but the test showed that it's not that bad, ok maybe not bad for high revving cars. Whether or not magazine testemonials are certified, it's something I cant say for certain.
so I scanned through that article.. I'd like you show me please if there's a particular thing that you wanna highlight
I can see that the stock manifold seems to perform better than all those manifolds including BBK-SSI up until 3900 rpm.. I was comparing the output at each RPM band..
I think you wanted to show me that BBK was the weakest in the low & mid power range.. nevertheless, after peak power, it stayed well on lead till 5900 rpm.. of course, there's also the highest cost as another con, and the pre-installed hi-flow fuel rails as a pro.
the GT40 seems to be the best performer throughout the whole range
and personally, I would buy a TFS Street Heat cuz of it's cost and good output. but hey, I got my Mustang and it had a Perfomer 5.0 - it works great for me.
Old October 31st, 2006, 01:26 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The other intakes out performed the BBK all over. I know a guy locally that got stuck on the BBK hype and lost 2 tenths when he changed from a TFS street heat to a BBK SSI.
Old October 31st, 2006, 11:06 PM   #14
2ndChildhood's Avatar
2ndChildhood is on a distinguished road
Anyone know where I can compare specs of the different intake mani's on a N/A 5.0?
95 Mustang GT Convertible.
95 Probe GT (KLZE)
85 VW Cabby
Threads Similar to: BBK Intake Manifold
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 21st, 2010 12:20 AM
Intake Manifold. Slicey 99-04 10 January 13th, 2008 05:50 PM
need a intake manifold matfernan1 99-04 22 September 28th, 2007 12:54 AM
Intake Manifold terribleonexx88 5.0 Mustangs 16 October 20th, 2006 12:54 AM
