94 Mustang GT
belt
have a 94 GT 5.0 look to get rid of the smog. what size belt do i need to by pass it?
spend $40 on a bypass kit from late Model restoration. keep the stock belt and make it look pretty. espicially if you already have pulleys.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
its $40 for basically another idler pulley right? my smog setup was already disconnected when i bought my car so i figure i might as well toss the pump too, anybody have tips on the other stuff i can toss too??
94 5.0 5sp GT 59 F-100 351 4sp 35's V8's for life... or atleast till gas hits $25 a gallon |
95 mustang gt
you can toss the stut bar an sway bar to also egr delete and move the battery to the trunk itll take off some weight in the front an put it in the back over the rear tires where you need it
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Threads Similar to: belt
| belt question | sixpack | 5.0 Mustangs | 0 | April 23rd, 2008 10:25 PM |
| belt size | 93lx306dev | 5.0 Mustangs | 0 | April 15th, 2008 06:50 PM |
| What size belt | nasty92LX | 5.0 Mustangs | 5 | September 29th, 2007 04:14 PM |
| belt for ud pulleys | gooberhead320 | V6 Mustangs | 6 | August 4th, 2007 07:14 PM |
| what belt? | Drgnracin72 | General Tech | 0 | June 23rd, 2006 03:58 AM |
