LinkBack (1) | Thread Tools |
#1
460 swap
does anybody know if the 460 swap kit for the fox body will work in a sn95?
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
1995 Mustang Coupe 3.8l
I'm not completly sure, but I do think it would.
1995 Mustang Coupe. 3.8l Auto. Bought for $800 and it shows. Swapping in 5.0l carbed. T5 Tranny. Goal 325HP. |
i was thinking the cradles were the same for fox bodies as the ones in the 94-95s
1989 Mustang LX
10.98@126.7 NA
Cradles are the same but there will be clearance issues with the headers. Major reworking needed or custom headers would be in order
Never fast enough.
are the strut towers the problem or the firewall?
i'd bet on both. you're putting a big ass piece of machinery in a relatively small car, so expect to pull out the cutting torch to make it fit comfortably
1989 Mustang LX
10.98@126.7 NA
Mostly k member, shock towers and steering shaft
Never fast enough.
a dohc 4.6 is close in width but the height is different right?
just get a 351 and bore it out to 427!!! save you hassle and be massive power
95' GT is being reconstructed! |
every one has a 351 im doing this for fun.
no replacement for displacement a bored 460 would just be fun to have
2005 GT & 69 Mach1
Yeah it will work. I also have the motor mounts if interested plus you will need some extra stuff I have info pm if you want
1999 Mustang
Holcomb Motorsports could help you with those questions.
![]() 1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq. |
Priest of the Car Gods
Considering a DOHC 4.6 has the same external dimensions as a 429, I can't imagine that it's unpossible, but it's not a car I'd want to drive - WAY too much weight up front for my taste.
1999 Mustang
wouldn't be too bad for a straight line race car but it's street manners might leave a little to be desired.
95 mustang gt
it will work but dont forget you need to convert to manual brakes because the valve cover wont clear the brake boost you will also need to go to manaul steering they make a manaul brake convertion kit in jegs for 159.99
95 mustang gt
the strut towers and firewall will be fine just have to buy the right headers
95 mustang gt
im not sure were to get them from but i know they sell them ive seen alot of sn 95 car with big blocks in them
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/68857-460-swap.html
| 460 in 67 Mustang Swap | This thread | Refback | May 15th, 2011 02:40 AM | |
Threads Similar to: 460 swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| Mach 460 Head Unit Swap Issues | SVrider | Audio/Video | 9 | February 8th, 2008 04:26 PM |
| 67 Mustang Meet 460 BB Help With Swap | suburban_concepts | Classic Mustangs | 9 | November 30th, 2007 11:47 AM |
| Headunit swap (mach 460) | Reset | Audio/Video | 24 | September 12th, 2007 06:23 PM |
| 460 swap | 20yrnotch | 5.0 Mustangs | 11 | February 27th, 2007 08:50 AM |
