Discussing Coolant or straight water for cooling in the 94-95 Forum. I was just wondering if I should run coolant or just water for a drag ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Coolant or straight water for cooling |
1995 Mustang GT
i don't see why you would use anything different than whats normally used (which is a 50/50 mix). but im not really sure
1995 GT, Ford Motorsports 'C' Springs, 2003 Cobra Bilstein Struts, Tokico Bullitt Shocks, MM Caster/Camber Plates, BBK x-pipe w/high flow cats, Flowmaster 40-series mufflers, B&M Short Throw Shifter, JLT True Cold Air Intake
Thanks for the reply; I actually got my answer from an official at one of the tracks. They would like all cars to run water and you can use a corrosion additive with it. I guess when a car spits antifreeze on the track it is a bitch to clean up.
my real drag car i always used str-water.cause if something broke...no antifreeze in bearings.....
1994 Mustang GT
dunno@we'll see
straight water. it absorbs heat better and it's not difficult to remove from the track.
1995 Mustang GT
hok... that's good to know.
you gotta use an additive to prevent corrosion
Speed kills drive an import and live forever. 1991 LX 5.0 H/B 1990 T-BIRD SC |
Threads Similar to: Coolant or straight water for cooling
| Let's Just Get This Straight... | TurboLX | The Clubhouse | 36 | April 10th, 2008 02:07 PM |
| So Let me get all this straight... | mustangmanic | 99-04 | 28 | September 9th, 2007 05:09 PM |
| Let's just get this straight | TurboLX | The Clubhouse | 63 | August 9th, 2007 03:01 PM |
| X, H, or straight pipes | Nick_Rapitis | V6 Mustangs | 20 | May 8th, 2007 02:11 AM |
| Water/Coolant shooting through tail pipes. | fallstar01 | General Tech | 4 | February 4th, 2006 06:35 PM |
