Discussing Grinding noise only while turning right? in the 94-95 Forum. I hear a metal-on-metal grinding coming from the passenger-front whenever I turn ...
Old May 5th, 2008, 08:12 PM   #1
1995 GT Convertible
I hear a metal-on-metal grinding coming from the passenger-front whenever I turn right, but not left. It is not the power steering, it only makes the noise while the car is moving. I'm assuming wheel bearing, but any other ideas? I'm going to replace the bearing this weekend and see if it helps.
95 GT Convertible
03 Cobra wheels, Kumo ECSTA Supra, slotted rotors, solid rear arms, Adj Koni's, Eibach springs, FMS clutch, Alum FMS driveshaft, T5 resealed,Adj camber plates, BBK long tube, Dr. Gas X pipe, Flowmaster, Fluidine rad, AC eliminator
Old May 8th, 2008, 11:53 AM   #2
Autotech's Avatar
I would say the noise is the rotor rubbing the backing plate, and the cause is excessive play in the wheel bearing... Sounds like you are on the right track!
www.freeautomechanic.com
Old May 15th, 2008, 07:26 AM   #3
1993 5.ohhhh
14.47 at 96 mph
tear the rim off check your suspension, but it might be tire rub.
99 towncar siezed motor
1996 v6 mustang 5 speed fed in the a by a bronco
1999 v6 auto drive way paper weight
1993 5.0 5 speed
http://i3.photobucket.com/albums/y51...thtrhtrhtr.jpg
Old May 16th, 2008, 02:22 PM   #4
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Sounds like sloppy / bad wheel bearing.
Never fast enough.
Old May 17th, 2008, 05:21 PM   #5
TKOTLARZ's Avatar
1994 GT
if the car is off the ground grab the wheel at 12, and 6 o'clock and see if theres any movement..if so its definitely your wheel bearing
TwistedWedgeHds,CompCam,Rockers,Springs,Rods,Valve s,HollySys.2 Up/Low Manifold, Coil,wires,F.R. Hders,F.M. X-pipe,supper44's,BBkregulator,AirInt,255lph,3.73, F.Length Sub.Con,Rear Up/LowControl Arms,lowered.315nitto555R
Old May 21st, 2008, 03:57 AM   #6
before you tear into things look at the strut and wheel and all over for any shinny metal services, might just be a rub
95' GT is being reconstructed!
Old May 22nd, 2008, 12:44 AM   #7
dag545's Avatar
1995 Mustang GT
N/A
Well I am just throwing this out there. On my 95 I have 18x10s and when I turn to the right it does the same thing you are talking about. What I cam to find out, it is my weights on the inside of my rims that is scraping agents my a-arm. so what rims do you have?
Threads Similar to: Grinding noise only while turning right?
grinding noise need help nba1341 Classic Mustangs 12 March 13th, 2008 01:15 AM
Grinding noise I_eat_rice V6 Mustangs 2 February 3rd, 2008 04:41 PM
Grinding noise I_eat_rice 99-04 2 February 3rd, 2008 12:02 PM
wierd grinding noise 96GTRagTop 96-98 45 September 14th, 2007 10:39 PM
Engine grinding noise help? 320hpPony? 5.0 Mustangs 2 May 21st, 2006 08:17 PM
