Discussing AC and Smog Delete Questions in the 94-95 Forum. Hey guys, long time no see. I started my spring build and ran into a ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1995 GT 5.0
14.66
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts. Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
89 GT
Theres a couple of ways to do it... and I'm a fox guy so this may be wrong but I'm assuming the accessories are similar if not the same. 1: remove the pumps and buy a p/s relocate kit so that your p/s gets moved to about where the A/C would have been or 2: get the extra pully that goes in place of the A/C pump. You can remove the smog pump and not have to get another pully, but when you do the A/C, you have to add the pully or move the p/s to make it work, otherwise the belt won't fit.
Parts needed: Full length headers and matching h-pipe For sale: Ford Racing E-303 cam brand new $100 BBK 65mm TB, brand new $100 BBK equal length shortys brand new $150 BBK off road x-pipe for shortys used $75 + shipping on all |
1995 GT 5.0
14.66
ok where do i get a relocate bracket and how do i remove the AC Junk/what can i remove, do i need to get different power steering hoses, and how long would the belt be when the power steering pump is relocated.
1986 Mustang GT
it'll be the top right. that's the configuration mine is running. with the power steering pump where the a/c was. i'm guessing the belt is 70.5". i haven't looked at it since i bought the car. it was already like that.
MILITARY CREW
AT3 |
89 GT
I got my relocate bracket from summit, it was around $40 IIRC. I'm about 99.9% sure that you don't need to change hoses on your p/s, I havent put my motor back in yet so i can't be 100% on that. I removed everything that has to do with my A/C under the hood. When you remove your smog pump, its a good idea to remove your cats because w/o the smog pump they will eventually clog and fail so get an o/r mid-pipe.
1995 GT 5.0
14.66
can i get a link to the bracket? i can't seem to find it. also how much do you want for your cam fogged?
1995 GT 5.0
14.66
Ok so i actually went to look at my belt system and that diagram is nothing like mine on my 5.0 HO. This is a rough sketch of my current setup:
![]() and i'm thinking i can pull off this belt setup: ![]() let me know what you guys think, has anyone done this setup? It'd be nice not having to move anything, just getting a smaller belt. My car won't be on the road for about another 3 weeks. Thanks
Threads Similar to: AC and Smog Delete Questions
| Smog delete | Timm10221 | 5.0 Mustangs | 0 | April 22nd, 2008 08:06 AM |
| smog and ac delete... | e3sean | 5.0 Mustangs | 7 | March 1st, 2008 01:31 PM |
| AC Delete and Smog Pump Delete | triplethreatt77 | 5.0 Mustangs | 14 | December 24th, 2007 06:09 AM |
| Smog Delete? | 95blackbeauty | 94-95 | 8 | December 20th, 2007 02:44 AM |
| Smog Pump Delete | mdvaldosta | 5.0 Mustangs | 2 | September 11th, 2006 11:13 AM |
