Discussing 3rd gear grinding in the 94-95 Forum. So. I got a problem. I have a 95 gt, 196,XXX on the odometer. ...
Old May 11th, 2008, 10:23 PM   #1
shroom's Avatar
Unhappy
3rd gear grinding
For about the First five minutes or so after start up, my car will grind when I shift into third. Once its in, its fine, no problems. But i can go back out, then into, and it'll grind again. Its only with third gear. After awhile, its gone. and only happens after its started. Then it'll stop.
Any ideas whats wrong????
Please PM me if you find out of any good deals on a terminator! Thanks!
"8/6/1945 little boy was dropped on Hiroshima......8/9/1945 FAT MAN was dropped on Nagasaki.....8/1/2002 Ford Motor Co. dropped the TERMINATOR on your Japanese ass"
Old May 11th, 2008, 10:29 PM   #2
maybe clutch
Old May 11th, 2008, 10:46 PM   #3
shroom's Avatar
Every other gear is fine. And I've made sure i pressed all the way too..
Old May 12th, 2008, 06:25 AM   #4
Bullitt95's Avatar
1995 Mustang GT AODE
13.97@100.9
Sounds to me like you have a worn 3rd gear synchromesh. The symptoms are invariably worse when the gear oil is still cold and thick.
Mod List
Old May 12th, 2008, 09:38 PM   #5
shroom's Avatar
How may i fix this problem, and is it expensive?
also, how hard would it be to fix this myself?
if you could explain what the synchromesh is, that would help too. if you dont mind.
Old May 12th, 2008, 10:20 PM   #6
sitting at idle, how hard is it to go from 1st to reverse.......
Old May 13th, 2008, 02:11 PM   #7
Bullitt95's Avatar
13.97@100.9
Unless you're expert at rebuilding manual trannies, I suggest you have it done by a specialist professional. It's not diffucult to fix, but it's also easy to screw up if you don't know what you're doing.
The synchromesh is what helps the gears to engage smoothly without grinding when you depress the clutch pedal. Here's a good explanation:
Manual transmission - Wikipedia, the free encyclopedia
Mod List
Old May 14th, 2008, 12:02 AM   #8
shroom's Avatar
Gotcha...so how would I present this to my local repair shop????? Cuz im not really sure, but i assume, etc. ??
Old May 14th, 2008, 01:09 PM   #9
Bullitt95's Avatar
13.97@100.9
Just describe the symptoms to your local repair shop and see if they agree with the diagnosis of a worn synchro. Your tranny will need a full rebuild anyway especially with 196k miles on it, and the high cost of a rebuild might make it more economical to just replace it with a new tranny. This might also be an opportunity to upgrade to a stronger tranny.
Old May 17th, 2008, 11:51 PM   #10
shroom's Avatar
Jesus.......I don't have money to really buy a new tranny, and Im selling this car at the end of the summer anyways......the tranny actually feels fine. Its been really smooth, shifts lnice and clean, up until this 3rd gear incident. You still think i should?
Old May 17th, 2008, 11:54 PM   #11
Modified88Dreamer's Avatar
88 Mustang GT
TBA!
I've seen how our transmission specialist rebuilt a transmission once. Some parts have to be pressed into place.
Originally Posted by DeMello View Post
wow your fucking retarded. A couple months ago you where asking the same questions I am
wats a k member?
wtfs a traction bar?
Old May 17th, 2008, 11:58 PM   #12
bullitt5576's Avatar
2001 Mustang Bullitt
really slow
lots of little pieces, and x2 for the 3rd gear syncro being worn out
Originally Posted by jivepepper View Post
Go buy yourself a dremel and do it yourself while the heads are still on the car.. That will really save you some money.
Old May 18th, 2008, 11:02 AM   #13
Bullitt95's Avatar
13.97@100.9
Since you're going to sell the car anyway and the symptoms from the tranny aren't that bad, you might as well leave it alone and soldier on.
Mod List
Old May 22nd, 2008, 12:41 AM   #14
shroom's Avatar
I probably will, just change out my tranny fluid and all. How much would it cost to get the 3rd synchro fixed btw?
Old May 22nd, 2008, 06:25 PM   #15
1995 Mustang GT
a shop probably wont just replace the 3rd gear synchros... they will have to order the full rebuild kit and replace them all. besides, the chances are, if you just replace the one, a second one will go out shortly after look on ebay for tranny's or look around for a wrecked car with a t5 in it (like in a junk yard) that has low miles. you could probably find one for 3-400 bucks if you shopeed around.
1995 GT, Ford Motorsports 'C' Springs, 2003 Cobra Bilstein Struts, Tokico Bullitt Shocks, MM Caster/Camber Plates, BBK x-pipe w/high flow cats, Flowmaster 40-series mufflers, B&M Short Throw Shifter, JLT True Cold Air Intake
Old May 23rd, 2008, 05:07 PM   #16
shroom's Avatar
know of any good donor cars that have them stock? Or any sites that sell trannies used or salvage web sites?
Threads Similar to: 3rd gear grinding
5th gear grinding emgjsdk1 Drivetrain 4 March 6th, 2008 09:51 AM
2nd to 3rd grinding EfylSetaf 2005+ 40 February 29th, 2008 02:41 PM
gear grinding Blk01ponyGT 99-04 22 September 19th, 2007 05:02 PM
1st gear grinding Luis_GT 2005+ 9 April 4th, 2007 07:05 AM
Gear Grinding... jerb43 96-98 18 October 31st, 2006 07:19 PM
