Will Not Run On 24LB Injectors
I cannot figure out for the life of me why my 95 Gt with a 347 Stroker will not run on 24LB injectors. I have Ford Racing 24Lbs and a Granatelli 90mm Mass Air that is calibrated to 24 lbs. It runs fine with the stock 19lbs. Any Ideas?
Double check the mass air flow sensor. If it runs when you put 19lb injectors in with that mass air but doesn't with the 24lb injectors, that tells me the sensor is either wrong or bad.
It runs with the 19lbs and the stock mass air sensor.
#4 | |
I agree, the problem lies in the Granatelli 90mm Mass Air Sensor
www.freeautomechanic.com |
If you have the stock GT ecu uprade it to the cobra ecu that ecu will work with 21lbs injectors and mass air. the stock GT ecu only works with 19lbs. Or you can have a chip burnt. Thats what you should do anyways
Threads Similar to: Will Not Run On 24LB Injectors
| 24lb injectors + air mass meter? | 1990CA50 | 5.0 Mustangs | 4 | January 4th, 2007 10:42 PM |
| What Fuel Presure For 24lb Injectors | chadjones99 | 5.0 Mustangs | 20 | September 10th, 2006 11:32 PM |
