Lookin for more HP - Page 2
Old June 3rd, 2008, 01:52 PM   #21
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Recalibrating the computer should be high on the list for 94-95 Mustangs. They have so many retard functions that kill horsepower. Those issues need to be taken care of to make the cars perform. These cars hate modifications more than speed density cars do.
Old June 3rd, 2008, 02:18 PM   #22
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
what do you suggest is the best way to go about doing that? chip? tuner? dyno?
Old June 3rd, 2008, 02:44 PM   #23
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
chip/tuner/handheld custom written tunes...
Old June 3rd, 2008, 02:45 PM   #24
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Take it to someone that is familiar with the T4M0 computer. If they are not familiar with it they will not know how to correct the issues. I'm not all too familiar with what they need to do but I do know some known issues with these computers which is why these cars are so much slower than fox body cars. The T4M0 computer is timing retard happy. It retards timing when you shift along with various other points and also has a different timing curve than the A9L computers. People have actually lost horsepower on these cars doing simple mods like a mass airflow sensor.
Old June 3rd, 2008, 05:24 PM   #25
1994 Mustang GT
DrHoward is on a distinguished road
I wouldn't bother with a dyno tune until you start getting more serious with it, my car barely idled when I installed my tfs1 cam, but until that point it's a fair bit of money for no alot of gain
And I have heard that they loose hp when you put in a larger maf, but keep in mind the maf off of a sn95 is larger than a fox body maf, and is typically large enough until you start making quite a bit more power
1994 Mustang GT HCI N2O yada yada yada
http://www.cardomain.com/id/bigshirtlesspete
Old June 3rd, 2008, 06:41 PM   #26
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Whether the MAF is larger on the SN95 or not has nothing to do with the fact that people have lost power installing them. The computer is totally different in SN95 cars.
Old June 3rd, 2008, 06:42 PM   #27
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Here is some SN95 reading material.
A9L vs. T4M0: THE SHOWDOWN
By: Mike Wesley
Some of you may be asking why the 94-95 Mustangs seem like they are so much
slower than the older cars. We've all seen them at the strip running quite a bit
slower. They are heavier, but the difference in times doesn't add up to the
difference in weight. What gives? Well, a lot of it has to do with the differences
between the '94 - '95 Mustang EEC and the '93 or older EECs. In 1994 Ford did
a major redesign of both the EEC hardware and EEC software. The end result
was a much 'cleaner', 'smoother' running car. If you own one of these Mustangs
or know someone who has one, you've probably heard of problems getting them
to start, idle, and run like a stock 1987 to 1993 5.0 after doing some
modifications. Well, you can thank the Feds and Ford for that. Ever increasing
emission requirements led to major changes inside the EEC to produce better
control of the powertrain. Of course this hurt the overall ability to modify the car. It
became much more sensitive to minor changes. With tighter requirements for
warranty, the '94 - '95 Mustang owner ended up with an engine that made the
same power numbers on the dyno, but not the same numbers at the track. Let's
go through some of the major differences and see if we can find the trouble
spots. This will be broken down over a series of articles, because it is very
complex.
PART 1 - EEC SPARK:
In the '93 and older EECs, spark advance at WOT (Wide Open Throttle) was
based purely on RPM. When you went into WOT, the EEC jumped to a separate
spark function to give whatever Ford thought was the best spark curve. Of course
we all know they didn't really make it, because you can pick up some power by
advancing the distributor. This wasn't their fault since the calibration was
designed to run everywhere with different types of fuels. Everytime you went to
WOT in a 93 or older car, you ran basically the same spark curve run after run. If
you look at figure 1, you can see a stock WOT spark curve taken from a 93 5.0
GT 5spd.
In the '94 - '95 cars, Ford made a major change to the spark calculations. The
WOT spark function was deleted and now the car uses the same spark tables for
both part throttle and WOT spark calculations. The problem with this is the spark
table is based on RPM and Load. The formula for Load is basically the amount of
incoming air, ratioed against how much 1 cylinder can hold at standard
pressure/density. You can sort of think of Load as volumetric efficiency. The EEC
uses the MAF to determine Load. It is a direct measurement of how much air is
entering the engine. You might be wondering what the big deal about Load is.
Well, since Load is used in the spark calculations, any change in Load will affect
how much advance you get. Since the EEC uses the MAF to determine Load,
any change in the MAF will change the Load calculation. Changes in the cam
and anything that puts more air into the cylinders will also affect Load. Change
the flow characteristics and you change Load. Let's see how this works.
To simplify the whole spark calculation, we are going to combine all the spark
calculations into one table and use actual Load values seen during testing. In
reality there are quite a few of them for different things. If you look at Figure 2,
you'll see a spark table from a 1994 5.0 GT 5spd. When you go into WOT, the
EEC will pull spark values from the top two rows of the table. Figure 3 traces a
test run done with a bone stock 94 GT. Notice how as RPM increases, Load
decreases and spark advances a bit. The decrease in Load is due to volumetric
efficiency of the engine dropping off. A typical 5.0 is not the most efficient engine
around. If you compare the spark values calculated by the 94 EEC to the 93
values, you'll see they are not too much different. Change something on the
engine and it's a whole new ballgame. Let's take a MAF change as an example.
Figure 4 shows a MAF transfer function for an aftermarket MAF that we tested
along with the stock curve. Notice how the aftermarket MAF's curve doesn't
always follow the stock curve? When the EEC looks at the aftermarket MAF and
converts the voltage into airflow using a built-in lookup function, it will calculate
differing amounts of Load as RPM increases. In our example, we'll use 5500
RPM and 4.6 volts out of the MAF. In our baseline car at 5500 RPM, the EEC
calculated a Load of .78. Input that into the spark table and we get an advance a
bit over 26 degrees. Going back to figure 4, at 4.6 volts the aftermarket MAF
'fools' the EEC into thinking MORE air is entering the engine than what really is
so it calculates a higher Load. With this particular MAF on our baseline car, we
saw a Load value of .91 and the resultant spark advance was 25 degrees. Wow!
By changing the MAF, we lost about 1.4 degrees of spark advance! On the dyno,
this particular car lost about 14HP when the aftermarket MAF was installed.
Some of this was due to the loss in spark and fuel which we will get to in a later
article. It looks like there is a simple fix to this by bumping the distributor up.
Sounds good, and it will help get back the loss in top end spark. However, there
could be a catch if we now look what happened to this car at 2500 RPM. The
baseline car had a Load value of .75 @ 2500 RPM and spark was 24 degrees.
After putting on the MAF @ 2500 RPM, the Load was .65, and spark was roughly
26 degrees. Hmm. We got more bottom end spark with the MAF since it 'fooled'
the EEC into thinking LESS air was entering the engine. Looks good so far and
the car did make more power at 2500 RPM than it did stock. Now to fix the top
end spark loss, we bumped the distributor up 5.5 degrees. This included the
'normal' 4 degrees everyone puts into the car plus the extra spark to compensate
for what we lost with the MAF. Now the car made up the lost power plus some on
the top end and lost 10 HP at 2500 RPM. Why?
Due to what the MAF was telling the EEC, and how it changed Load and
advanced the spark 2 degrees, our bump in the base advance made the total
spark advance at 2500 RPM a bit over 30 degrees. Way too much advance at
2500 RPM. Figure 5 shows the relationship between torque and spark advance.
The very top point in the curve is called MBT or Maximum Brake Torque spark.
It's basically the amount of spark advance that produces the maximum amount of
torque. If you go above or below the MBT point, you lose torque. As you continue
to advance the spark, you'll reach a point in the curve called BDL spark or
Borderline spark. This is the amount of spark advance where the engine just
begins to knock. On a normally aspirated, low compression engine, BDL occurs
at advance values higher than MBT. On high compression or supercharged
engines, BDL can occur at advance values lower than MBT. Raising the octane
value of the fuel moves the BDL point higher up. Going back to our low RPM
example, further testing found the MBT point at 2500 RPM to be 28 degrees.
Now came the question of what to do. Should we lower the base advance to get
the bottom end power back and sacrifice some top end power, or leave it alone?
However, should we go for the top end power, but sacrifice the bottom end? That
choice is up to the owner. We opted to actually re-calibrate the EEC to run MBT
spark at all RPM points by changing the spark tables. Now of course all this
might go the other way depending on the MAF. It can 'fool' the EEC into lowering
the Load at higher RPM which will give you more advance. It's really hard to tell
what you are going to end up with.
Another thing the '94 - '95 cars do with spark is retard it during a shift. The
automatic cars REALLY pull out the timing, but the 5spd cars do it also. Inside
the 5spd EEC calibration is a thing called Tip-in Retard. Any time the throttle is
moved from a more closed position to a more open position, it can pull out some
timing. When you shift a 5spd car, most people lift off the gas during the shift.
The EEC senses this, and when you push on the gas again it pulls some timing
out. The older EEC didn't have this 'feature'. You lose more torque during a shift
on a '94 - '95 car than a '93 or older car. Why did Ford do this?? We think
warranty. Ford had to replace a zillion T-5's in the older cars. Alot of them broke
due to overshifting and power shifting, but alot of them broke as a result of too
much transient torque. If you could reduce the torque output of the engine during
a shift, the transient torque would be lower. The trans wouldn't break as easily,
and thus the Tip-in Retard was born. How much timing is pulled out during a shift
varies, but it can pull out as much as 15 degrees. There is not much you can do
to 'fix' this except to re-calibrating the EEC.
The '94 - '95 automatic cars have a torque modulation strategy installed in them
to vary spark during shifts. When the EEC thinks it's time to change gears, it can
pull out massive amounts of timing so the shift is nice and smooth. As far as we
know there are two reasons for this. First is warranty. The AODE trans is not all
that strong in stock form. By reducing the torque during shifts, you can extend it's
life. Second is shift feel. For some reason Ford doesn't want you to 'feel' the car
shift. Ever notice that just about all Ford vehicles with electronic transmissions
shift like Town cars? Smooth and sloppy. Even performance vehicles like
Mustangs and Lightnings have weak kneed shifting. What fun is that? The
downside to this smooth, sloppy shifting is increased wear. Ford tends to slip the
trans too much during gear changes slowly burning it up. Manually shift your car,
and you'll see it shifts much better. During manual shifts you run through different
sections of the trans control strategy. The older EECs with AODs (sometimes
called DOA's) really had no idea a trans was attached to the engine. They did not
spark retards during shifts and could actually shift quite well. They broke more
often, but shifting was better. Adding a shift kit to a '94 - '95 car can help the shift
feel by increasing fluid pressures inside the trans, but this does nothing to the
engine torque loss during a shift.
So you can probably see, tuning a '94 - '95 Mustang can be tricky. The engine
remained basically the same, but the brains controlling it changed. In the next
article, we'll discuss the fuel system and how minor changes to the engine can
have drastic effects on how the engine runs.
Old June 3rd, 2008, 09:39 PM   #28
1995 Mustang GT
N/A
Colt45bennett is on a distinguished road
Send a message via MSN to Colt45bennett
so get my computer re calibrated first before i get any of the parts
Old June 4th, 2008, 04:47 PM   #29
95StangMX's Avatar
95 Mustang GT
not to be rude but I would stay away from the alphabet cams jlaw there are alot better cams out there now or get a custom grind depending on what you are going for and as far as nothing lower than 4:10 gears thats the absolute lowest I would go if you plan on driving the car on the street much I would say 3:73 - 4:10's and what darrell is saying is not get a tune first get your mods together and get it tuned because our cars dont respond well to mods without being setup for them thats why I am doing my whole thing at once the stroker heads cam intake nos and all supporting mods and a tune....just my opinions though....but darrell knows his stuff
Old June 4th, 2008, 05:55 PM   #30
WildWill's Avatar
1995 Mustang GT
Thank you, Darrell.
Old June 4th, 2008, 06:23 PM   #31
95StangMX's Avatar
95 Mustang GT
yeah no kidding thats a great write up and should definately be posted as a sticky here in this section at least I think so ... it has a ton of info that alot of 94-95 users should or need to know when doing mods....now i just need to find someone that has about the same setup as me and see if i can use that tune .... the chances of me finding a dyno or someone to tune my car here are about slim to none...anyways I vote STICKY....is it possible to change out the eec's on our cars to one from a pre 94 or is that a ton of work? and can the computer be retuned to run good with mods?
Old June 4th, 2008, 11:46 PM   #32
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
if you dont have that much money i would definitely start with 4.10's, exhaust and cold air...you'll be really happy with the results
Cohagan Engineering, Inc.
Old June 5th, 2008, 01:45 AM   #33
1995 Mustang GT
N/A
ok so i think i got it
go wit my Flow master pipes /w x pipe
then a K&N air intake
BBK Long tubes headers
then if i have money by end of this im gonna redo the top end
then go wit the tune
Old June 5th, 2008, 10:15 AM   #34
MikeD05GT's Avatar
2005 Mustang GT
4.10 or gtfo....i dont see the point in 373's even on a high hp car..if you have suspension and good tires your not going to spin...
Old June 6th, 2008, 12:50 PM   #35
95StangMX's Avatar
95 Mustang GT
this kid is planning on driving this everyday and with 4:10's he's gonna burn alot of gas and have no top end
Old June 6th, 2008, 05:31 PM   #36
MikeD05GT's Avatar
2005 Mustang GT
wtf are u talking about no top end? the 4.10's can go to 160 mph and the car isnt going to go that fast it doesnt have the power or areodynamics?? so dont say it wont have a top end...and gears dont hurt gas milage buddy having a lead foot from the new found ass dyno causes bad MPG
Old June 6th, 2008, 07:52 PM   #37
TKOTLARZ's Avatar
1994 GT
4.10's dont kill your city driving ..and only about 2-3 miles less on the highway..i got 3.73 and wish i would have put the 4.10's in..my friend has a fox with 4.10's and its great..i wouldnt get a tune until you get some work done to it..a tune-up would be good, and put royal purple motor oil in the car if it doesnt have it already..
Old June 6th, 2008, 10:32 PM   #38
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Please show me a mildly modified Mustang with 4.10 gears that goes anywhere near 160mph.....
Old June 7th, 2008, 12:34 AM   #39
1987 ford mustang gt
well see when shes done
Please shut the fuck up. A car with 4.10's in it would be lucky to reach 125/.
Old June 7th, 2008, 11:06 AM   #40
MikeD05GT's Avatar
2005 Mustang GT
160 was a reach
Threads Similar to: Lookin for more HP
lookin for a how to mikethetigerrr V6 Mustangs 4 May 18th, 2008 12:26 PM
lookin.. moosenuk17 99-04 0 April 19th, 2008 12:28 AM
Lookin for a 5.0 Squints 5.0 Mustangs 35 December 31st, 2007 06:01 PM
Lookin for some help Emay The Clubhouse 4 December 31st, 2007 05:27 PM
