#41 |
whos goin 125 on the street
#42 |
1987 ford mustang gt
well see when shes done
#43 |
1995 Mustang GT
this was a good thread until somebody went and screwed it up with an argument about gears. if you want to argue about gears... again... please do it in another thread.
#44 |
2004 Mustang SVT Cobra
448whp/475wtq
a bit of info here too i have a mildly modified 95 GT with 3:55s and it does 4th gear 123MPH @5,900RPM.
#45 |
yea people were supposed to be talking about parts to gain hp not fighting about gears
#46 |
Is there a place I can send my ecu to get it modified? or some sort of map I can get for it?
or can I use the A9L ecu in my 94 stang? Last edited by vinniepearl; June 9th, 2008 at 04:54 AM. |
#47 |
I now have read that I don't need the A9L. So strike that.
#48 |
1995 Mustang GT
i have the same question?
#49 |
You can but I don't have much info to share on that. I know people have made the switch but I have no experience with it so I don't have any details for you. Google is your friend.
#50 |
(I doubt you'd feel a SOTP difference with the pulleys but they certainly deliver very good bang for the buck (e.g. ~5rwhp from an ASP underdrive crank pulley costing only $39 at Summit Racing))
Do u need a different belt for this |
#51 |
Indeed you do. When I removed my smog pump I needed an 89.5" belt. After installing the ASP underdrive crank pulley, I needed an even shorter belt and found that the Gates K060868 (86.8") was a perfect fit.
![]() 244whp/284wtq Mod list in My Garage |
#52 |
95 Mustang GT
I didnt know gears added HP... the post is lookin for more HP....BTW just screwing around dont want to get a bunch of peoples panties in knots....
#53 |
how hard is it to remove the smog pump
#54 |
Easy, but you'll need to remove the air filter assembly first so that you have enough room to work in. With the belt off, you only have two long bolts to remove in order to pull the smog pump off its mounting bracket. Here's an excellent article detailing the procedure:
http://www.allfordmustangs.com/techarticles/Smog2.pdf
#55 |
do u hafta have the delete pulley kit?
#56 | |
2002 Gt
Not Slow
![]() iTrader: 1 reviews
id fux with the gears before anything else,.. gears,shifter, exhaust, intake.. and that should be a blast,.. when you begin getting bored of that,.. than you can get deeper into the tuning world,.. or if a chevy beats you |
#57 |
2002 Gt
Not Slow
#58 |
Not necessarily. The smog pump delete pulley allows you to reuse the stock belt in its normal routing, but you can do without it and use the aforementioned shorter 89.5" belt. You'll need to route it slightly differently as shown here:
Free Modifications
Threads Similar to: Lookin for more HP
| lookin for a how to | mikethetigerrr | V6 Mustangs | 4 | May 18th, 2008 12:26 PM |
| lookin.. | moosenuk17 | 99-04 | 0 | April 19th, 2008 12:28 AM |
| Lookin for a 5.0 | Squints | 5.0 Mustangs | 35 | December 31st, 2007 06:01 PM |
| Lookin for some help | Emay | The Clubhouse | 4 | December 31st, 2007 05:27 PM |
