Discussing building block... in the 94-95 Forum. now that i'm thinking about it... in your opinion, would it be worth it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1995 Mustang GT
building block...i have a kenne bell blowzilla supercharger on the list and i think i want a trick flow top end... would anyone recommend anything else? is it a better route to go with gt40 upper and lower with the KB?? but my original question... i'm probably going to have internals replaced, so should i just buy a newer block or build the one i have? any opinions are appreciated.
1995 GT, Ford Motorsports 'C' Springs, 2003 Cobra Bilstein Struts, Tokico Bullitt Shocks, MM Caster/Camber Plates, BBK x-pipe w/high flow cats, Flowmaster 40-series mufflers, B&M Short Throw Shifter, JLT True Cold Air Intake
1995 Mustang GT
does anyone know where i can buy one of the new BOSS blocks... i'm looking for the BOSS long block crate engines that have the "Ford Racing GT-40X" aluminum heads ????
forging your internals is a waste of time in my opinion! why do that because you can get cheaper rods and crank that will handle more power than the stock block will hold...
if you want to put that much out at the wheels and have no worries about splitting the block you might look into a nice after market block or building yourself a 351, which can both handle a significantly higher amount of power, 351 would be cheaper just a suggestion... thats what i would do ![]() Dart 31384185 - Dart SB-Ford Iron Blocks - JEGS boss block: Ford Racing M6010BOSS302 - Ford Racing Boss 302 Engine Blocks - summitracing.com and i believe if your use a roots type blower "kenne bell" you would use the intake from the company designed to work with the s/c
95' GT is being reconstructed! |
1995 Mustang GT
Think long and hard about what you're getting into. Gas prices aren't getting any lower and if this is your DD you'll be ass raped by them. Give Woody at FordStrokers.com 331-347-393-408-418-427 stroker kits and ford parts. a call and he can build you something to fit your needs. I bought my 347 from him, great guy to deal with.
See garage for mods |
Threads Similar to: building block...
| Boss block or Dart block??? | JONJON | 5.0 Mustangs | 48 | November 6th, 2007 09:37 AM |
| short block differs from a long block how? | mustangfox9091 | 5.0 Mustangs | 35 | September 26th, 2007 10:57 PM |
| short block vs long block? | caintcatchmyGT | 96-98 | 3 | July 22nd, 2007 09:47 PM |
| Small Block or Big Block? | Speedstang302 | 5.0 Mustangs | 8 | April 16th, 2007 10:58 AM |
| building the block? or supercharging | sportsplaya2134 | 5.0 Mustangs | 3 | April 8th, 2007 04:56 PM |
