Motor Swap From 95 GT.. Will It Fit?
Old November 4th, 2006, 05:02 PM   #1
81 Merc. Capri is on a distinguished road
Send a message via MSN to 81 Merc. Capri Send a message via Yahoo to 81 Merc. Capri
i got a wrecked 95 gt conv. my girl friend tried 2 climb a tree with, motor was untouched in wreck, will this block fit in a fox body or is it different, looks same but my "Ford buddy" says it won't, is he right or all 5.0's the same?
So many Camaros... So little time....
Old November 4th, 2006, 09:35 PM   #2
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
Re: Motor Swap from 95 GT....will it fit?
YES
DUDE...man whats he talking about, the 5.0 are all the same from 68-98 (there were 5.0s in explores) In 86 I believe they went to a roller cam, then in 94 they have an electric fan not belt driven. SO yes it will fit in the fox the whole engine will! You will just have to make the fan mechaniclly driven by the belt, like the foxes were. 94 the computer controlled the fan thats the difference, and the ditributor is different b/c the ignitoin module is on the distributor in the fox 302s but in 94 up it was on the fenderwell under the intake box.
O and also if the 302/5.0 is out of an explorer or pick up truck the 302 is the same engine motor mountsand all. The diff. from truck to mustang would be cam and heads.
Old November 4th, 2006, 10:50 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
yes the block will fit, same block as a fox 5.0.
fox vs sn95 diff.
intake
tb
maf
ecm
fan
tfi location
egr location
a few others like cam specs
BTW 5 liter heads are a ford truck head hence E7TE, T for truck.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 5th, 2006, 11:09 AM   #4
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
does anyone have a 5.0 for sale ????
Old November 5th, 2006, 11:11 AM   #5
and if you need a new brain for your 94 or 95 does it have to be from a 94 and 95??or cn it be from any other car or truck with a 5.0??
Old November 5th, 2006, 08:45 PM   #6
what year Exploders have those aluminum heads i keep hearing about, does the truck intake really flow better than cobra intake?
Old November 6th, 2006, 09:43 AM   #7
92_fox's Avatar
92_fox is on a distinguished road
im pretty sure 94 and 95 are stand alone but to make sure ill ask my boss, and if you need a 5.0 were do you live, i work in a mustang scrapyard we have plenty of 5.0's
were located in jackson nj
92lx, bbk hpipe, flowmaster cat back, underdrive pulleys, bbk cai, msd pro billit dizzy and more to defff come
Old November 6th, 2006, 08:34 PM   #8
92_fox's Avatar
ok i talked to my boss and the 94 is a stand alone but the 95 a ecu out of a 95 to 97 will work in it
Old November 6th, 2006, 09:00 PM   #9
lugthug713's Avatar
2002 Roush 360R
Man I am pretty sure your boss is wrong about that. 94 95 had 5.0s 96-98 had 4.6. 2 diferent engines they would have diff. ecus.
I think the truck ecus would be diff. from the mustang
I think its the 96 97 98 explorores that had the gt40 heads on them.
Old November 6th, 2006, 09:17 PM   #10
92_fox's Avatar
i thoguth about that but idk i no the 94s are stand alone so maybe the 95s are to i thoguht that sounded a little wierd my bad
Old November 6th, 2006, 09:23 PM   #11
lugthug713's Avatar
2002 Roush 360R
no man its cool i was just cleering that up. But yes you where right and he wasnt. but the 94s and 95s have a diff ecu then the foxes, and the 96-up are diff. also
Old November 6th, 2006, 09:30 PM   #12
92_fox's Avatar
yea the 94s and 95s had the electric fan and the gauages are diff so if u used as fox one the fan and some of the gaugeous i heard wont work
Old November 15th, 2006, 10:49 PM   #13
94cobraclone's Avatar
94cobraclone is on a distinguished road
yeah you wont have any problem putting that motor in. If you are worried about the puter then just get the one for an A9L to use in your fox body. I think that one will work but not sure.
I saw some 5.0 on ebay for 495-695 plus 375 shipping from new mexico.
question why are the 94-95 called sn95's? I have had a 82 gt that i pulled the 5.0 out and put in a 5.8. Now I just bought this 94 n ebay with the 5.0 and powerdyne. so i am new to this body.. thanks.
Powerdyne supercharger
Ebrock perf upper/lower intake
Steeda 18 cam
GT-40 heads
MSD Ignition
All forged bottom end
BBK headers
3:73 rear end
T-5 Manual Trans
Old March 2nd, 2007, 06:34 PM   #14
Look Ma! My First Post!
66stang is on a distinguished road
My Question is along the same lines. The first guy to respond said that the engine blocks were the same size from 68 and beyond so i was wondering how so if there differnt in 66. I have a 302 motor out of either a 70s or early 80s LTD and im encountering problems with clearance for the oil pan. Any one Know why this is? Or what i can do to resolve that? This restoration and engine upgrade is all new to me
Old March 5th, 2007, 10:11 AM   #15
mustangman9550 is on a distinguished road
Thar motor will fit but like said before need the ecu to go with PLUS the transmission imput shaft is longer on the 94 95's but if you get the tranny along with the 5.0 you should be alright.....
Threads Similar to: Motor Swap From 95 GT.. Will It Fit?
Motor Swap 96gt cobra powered 96-98 5 August 31st, 2007 08:23 PM
Motor Swap ShaneMiller 94-95 9 May 19th, 2007 08:52 AM
motor swap? El_Cangri V6 Mustangs 37 April 8th, 2007 09:12 PM
motor swap 4 cyl to 8 ??? sk8daily69 5.0 Mustangs 3 December 25th, 2006 02:22 PM
Motor Swap 68 dlxcoupe 96-98 3 November 1st, 2006 01:44 PM
