Discussing how much fluid in the 94-95 Forum. how much fluid does a 95 t-5 tranny take... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1995 Mustang GT
how much fluid |
1995 Mustang GT
nvm i found out
1995 Mustang GT
so how much is it? share...
1995 GT, Ford Motorsports 'C' Springs, 2003 Cobra Bilstein Struts, Tokico Bullitt Shocks, MM Caster/Camber Plates, BBK x-pipe w/high flow cats, Flowmaster 40-series mufflers, B&M Short Throw Shifter, JLT True Cold Air Intake
1995 Mustang GT
it was 2 4/5 quarts for the t-5
1995 Mustang GT
It's not quite 3 qts. Best way to do it....drain it all out using a 3/8 drive ratchet and extension on the bottom plug. Put the plug back in and remove the top plug. Remove shifter and pour in 2 qts. Get a friend to look under the car as you start to pour the 3rd qt in. When it starts coming out of the top plug you're good to go. Put the plug back in and bolt the shifter back down and you're done. If you don't have a friend to help you I believe it takes alittle more than 2 1/2 qts.
See garage for mods |
Threads Similar to: how much fluid
| Fluid Changes | Exile | 94-95 | 4 | April 2nd, 2008 10:33 AM |
| T5 Fluid Question | 1986GT | 5.0 Mustangs | 9 | February 26th, 2008 03:15 PM |
| Wiper Fluid | Shelby0767 | V6 Mustangs | 6 | February 18th, 2008 11:01 PM |
| Fluid color | JASonic | V6 Mustangs | 30 | October 5th, 2007 02:17 PM |
| tranny fluid | Mustang RacR94 | V6 Mustangs | 1 | April 29th, 2007 10:18 PM |
