Intake Elbow
Where can i get the elbow to run pre 5.0 intakes? I have a gt40 intake off of an explorer but need the elbow
![]() 95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete BOOSTED |
1995 Mustang GT
Summit sells them, you can check ebay. Any elbow will work, depends on how picky you are when it comes to matching the upper.
See garage for mods |
1987 ford mustang gt
well see when shes done
Those are for a carbed intake converted to efi such as the super victor efi intake and they mount to a 4150 or a 4500 style carbed base.
1994 Mustang 5.0
The GT-40 Explorer setup is nice, it will provide you with allot more power in the higher RPM range. You will probably loose a little bit of torque on the bottom end but not much and the upgrade is definitely worth it. I found mine on eBay for around 50 bucks, so they are out there for cheaper than 100. Good luck finding an elbow, and I would stay away from theEdlebrock ones as the bottom right hole is a pain on them. All the others seem to be about the same. You will want to pay attention to the bore through them though, deppending on what size TB you use and if you are going to port the size of the inlet on the intake plenum from 65mm to whatever you need. Hope that this helps you out a bit.
1994 Mustang GT
ford racing discontinued the svo elbow, but if you call them they know of one shop left with a small supply if them, thats where i got mine and i love it cause it says svo on it and thats like saying bad a$$ old school for the sn95
#7 | |
![]() GT40P heads, Explorer upper and lower intake, BBK underdrive pulleys, 1.7 roller rockers, 4.10 gears... Now looking for this elbow and a CAI kit.. Tom |
Is there any drawback to using the elbow off of the explorer intake? I know that it probably wouldn't work on your mustangs but mine is going on a 23T. Just wondering if there is some major performance drawbacks.
'74 bronco rockcrawler, '03 Rubi, '06 GTO |
Threads Similar to: Intake Elbow
| Intake Elbow | 95blackbeauty | 5.0 Mustangs | 2 | June 12th, 2008 09:09 PM |
| I hyperextended my elbow. | Dansby | The Clubhouse | 2 | May 25th, 2008 07:12 PM |
| My elbow hurts.. | MustanG_guy17 | The Clubhouse | 25 | November 7th, 2007 06:12 PM |
| Type V6 Mustang with your elbow! | Nick_Rapitis | The Clubhouse | 53 | May 11th, 2007 08:54 PM |
| 5.0 after a lot of elbow grease | dr.gonzo! | Pictures | 6 | April 29th, 2007 02:44 PM |
