#21 |
I was just letting you know what I did. I bought the Haynes manual and thats what it said do to adjust the clutch and it worked for me.. Just a suggestion bro.
![]() Ain't No Tamin' This Stang! |
#22 |
1995 Mustang GT
update.... i went to adjust the clutch today, and found that on the cable, there was no nut or any visible way to tighten the cable up, so i scratched that idea and went under to the firewall to see if i could adjust it there, and again, there seemed to be no clear way to tighten the cable up, so what i did was crank down on the position of the pedal (so in essence, putting pressure on the cable) just enough so that the squeaking stopped. so, for now, there's no squeak, but obviously its just a temporary fix.
when i took the cable box cover off, i found that it was actually extremely loose. i could wiggle the bearing fork around very easily without there being any pressure on the cable at all. so, my question is, now that i have essentially tightened the clutch pedal down so that there is a slight amount of pressure on the cable (like i said, just enough pull to stop the squeak), if i tightened it up to much, how will i know? when driving it this afternoon, it def felt like all the power was getting to the ground and there was no apparent slipping. but if i did tighten it up just a tad to much, what might i the consequences be?
#23 |
1994 GT
if u tightened it to much it would slip, causing alot more clutch wear.. the bearing should just sit on the teeth and not disengage the clutch at all..i know mine felt fine until i hit 5 grand, it would slip from 5-6grand so u might wanna check that...but the fork should be able to move up and down a little , but not from the front to back of the car.. whenever you decide to change the bearing out, you should really invest in a firewall adjuster,it does wonders lol
Cohagan Engineering, Inc. |
#24 |
1995 Mustang GT
ill test it at higher rpms later today... i will def invest in that adjuster. i think im gonna replace my clutch cable as well. im gonna just try and hold out for a few more months till i do my tranny swap, then ill be sure to replace everything else too...
thanks for all your help guys.
#25 |
1994 GT
just watch the routing of the cable, if you route it wrong it will eat that cable right up and make it stiff as shit..no problem..let me know if u need any more help
#26 |
It's possible that it could be a few things.
Clutch pedal clutch quadrant if you have recently detailed your engine bay "could have gotten some finish on the clutch cable clutch fork could be getting a little noisy worse case, could be your throw out bearing |
#27 |
1994 GT
its definitely the throw out bearing and clutch forks cant make noise.
#28 |
1995 Mustang GT
it hasn't made the noise since i tightened the cable a few weeks ago... so for now im not worried about it. im sure its certainly the throw out bearing.
#29 |
94 cobra
i have this same problem and i am going to replace it i was wondering what the best one to use is and if there was a kit or something. also if anyone has a diy for the throw out beraing. i had one other question to my buddies sells car and his mechanic said if im going to replace the bearing i may as well do the clutch i'm at 85k miles(94 cobra) my clutch feels fine to me and has no problems so i cant see spending 400 to fix something that has nothing wrong i was wondering what you guys thought
#30 |
1994 GT
when you replace the bearing, take the clutch off and take a look at it. that is a good amount of miles for a clutch that is probably getting ripped on..im just assuming its been driven that way... but i bought my throwout bearing from pro-motion when i picked up my tranny. its only one piece but you want to make sure you put some white lithium grease on the face of the bearing.
#31 |
94 cobra
yeah my buddy told me to just wait and do the clutch and bearing at the same time. can anything bad happen from driving it with a bad T/O bearing ??
#32 |
1995 Mustang GT
from what i understand, no... it just gets louder and a bit more annoying. but might as well wait for your clutch to go before you do it. im waiting to replace my whole tranny!
#33 |
94 cobra
ok sounds good then i'll wait cause i can deal with that
cobra R hood (has a vin#) bassani catback flows welded in jegs O/R H-pipe Jlt CAI Mgw shifter 03 cobra rims 3.73's (on the way!!!) |
#34 |
2000 mustang GT
yeah im havin the same problem
this really helps |
#35 |
f'n throwout bearings. mine ticks some days and some days it doesnt LOL just enough to piss me off i guess. good read right here and hey will is everything still ok?
-2003 TERMINATOR- -2006 MUSTANG GT- |
#36 |
94 cobra
mines still running fine squeks loud some days hardly at all others
#37 | |
2000 mustang GT
#38 |
yeah my flows block it out alot too lol
#39 |
1995 Mustang GT
yeah its all good man... since i tightened up my clutch cable i haven't heard it since. i'll get around to swapping it eventually...
Threads Similar to: clutch related squeak...
| Clutch squeak | travis_afx | 99-04 | 10 | April 4th, 2008 02:46 AM |
| Clutch.. pp aand all those related tranny parts Q's.. | El_Cangri | V6 Mustangs | 6 | June 28th, 2007 05:19 PM |
| squeak | mustang1072 | V6 Mustangs | 5 | February 21st, 2007 11:34 PM |
| squeak | stang638 | V6 Mustangs | 31 | February 11th, 2007 04:33 AM |
| Squeak Squeak! | DC97Cobra | General Tech | 4 | November 26th, 2005 12:13 PM |
