Engine dies when clutch is pressed
While driving around town my 95 gt has started dieing when i come to a stop light or sign etc and push the clutch in. It starts right back up and act as if nothing happened until i get going and come to another stop sign. No rough idle, no lack of acceleration or anything. and it starts right back up every time. Any ideas?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1989 GT
KB 2.1L Flowzilla
I had similar problems when i got the idle speed controller plug loose.
Threads Similar to: Engine dies when clutch is pressed
| Waxed,cleaned,and Pressed | BLACJAC | Pictures | 17 | May 31st, 2008 09:59 PM |
| Engine dies coming off hwy | frankyees | 99-04 | 11 | October 13th, 2007 02:52 AM |
| PI Cams With or With Out Pressed Gears? | tlgrant | 96-98 | 4 | November 2nd, 2006 07:54 PM |
| Engine Dies While Driving | Mystic Mama | 96-98 | 7 | May 6th, 2006 08:55 PM |
