Very Confused... please help.
Old July 11th, 2008, 03:02 AM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
I have a '95 GT and the power seat and the cigg. lighter both don't work and they are both run off the same fuse so my first and really only guess would be that fuse. but its not. i changed the fuse and still nothing. what am i missing here? thanks in advance.
Old July 11th, 2008, 04:16 PM   #2
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
yeah they are on the same fuse. Did you check the fuses under the hood in the Power distribution box?
See garage for mods
Old July 11th, 2008, 07:33 PM   #3
burnout5.0's Avatar
448whp/475wtq
yeah the the only fuse for them is under the hood and its good.
Old July 12th, 2008, 12:57 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is there power to the fuse? The fuse should have a small slot on each side that you can probe with a test light. Take a test light and probe the slots of the fuse. You should have power at both terminals. If not the fuse is bad. If there is no power at either terminal then you obviously have no power at the fuse and the problem is between the fuse and the power source. If there is power at both terminals then the problem is between the fuse and the accessories. Could be a broken wire, bad ground, bad relay, etc. Isn't the power seat on a circuit breaker or is that just the windows. I can't remember...
Old July 12th, 2008, 03:12 AM   #5
burnout5.0's Avatar
448whp/475wtq
is it possible a relay could blow? if so which one?
Old July 12th, 2008, 10:03 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It is possible. Before anything you need to isolate the problem which doing what I said in the above post is a good place to start.
Old July 12th, 2008, 03:35 PM   #7
burnout5.0's Avatar
448whp/475wtq
ok i fixed it. It was a fuse but not the one stated in the shop manual that runs the power seat. weird. but whatever im happy, now it works.
Threads Similar to: Very Confused... please help.
confused...need help. 8notch8 2.3 Mustangs 7 July 27th, 2008 04:45 PM
I'm a little confused... D-Brow General Tech 4 July 26th, 2007 08:25 PM
Ok, confused about this: shroom 99-04 61 April 1st, 2007 06:30 PM
somewhat confused sirpullsalot General Tech 4 January 16th, 2007 11:12 PM
