What's correct amount of ATF
Old July 14th, 2008, 10:59 AM   #1
rru95GT's Avatar
rru95GT is on a distinguished road
Hi.
Can anyone clarify to me what's correct amount of ATF in 95 GT equiped with AOD-E tranny.
With / without (std.) torgue converter.
It's so darn hard to see it in a dipstick when there's a new oils in it.
And if you drain your TC also what's the correct procedure to refill the whole tranny?
Old July 14th, 2008, 02:49 PM   #2
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
Did you drain the TC? In my opinion it's best to do it all at once. If you didn't empty it and you just drained the pan and changed the filter you're only going to add 4 qts. If you drained the TC too you'll end up filling it with 12.5 qts. With the car in park and the e-brake on run the car at a fast idle but don't race it. Move the shifter through all the gears a few times and back to park.
See garage for mods
Old July 14th, 2008, 04:07 PM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
12.5 qts according to my Haynes manual.
243.5rwhp/284.2rwtq
Mod list in My Garage
Threads Similar to: What's correct amount of ATF
Small amount of wobble SLayer7391 2005 - 2010 21 June 27th, 2008 07:09 AM
Safe amount of SC boost tyzride General Tech 1 June 15th, 2008 12:12 PM
Gear Oil or ATF? 00gtCoolGuy 99-04 4 November 22nd, 2007 08:09 PM
ATF + Oil Change Via Disptick provinggrounds V6 Mustangs 11 June 13th, 2007 11:20 AM
ATF Fluid in T5 Transmission? From Tech Article 83 5.0 5.0 Mustangs 12 August 29th, 2006 10:26 AM
