Passanger Power Window Issues - Forums at Modded Mustangs
post #1 of 10 Old July 16th, 2008, 01:35 PM Thread Starter
What it does people? Im new to this website but everyone on here seems pretty kool so I was wonderin if anybody could help me fix my power windowon the passanger side? I checked the connections thinkin it might have slipped off but its not. I also checked the fuses but dont know which one to look for. All advice is appreciated thank you.
MrCobraGhost is offline
post #2 of 10 Old July 17th, 2008, 09:12 AM
Mustang RacR94's Avatar
Send a message via AIM to Mustang RacR94
if its not working listen for the window motor, if you hear it buzzing when you go to use the window its most likely good. if its not that its a window regulator, usually just makes a dec loud click/clunk sound and doesnt go anywhere, sometimes you need to just need to tighten the rails the windows are on.
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Mustang RacR94 is offline
post #3 of 10 Old July 17th, 2008, 03:36 PM
mustangfu's Avatar
Send a message via MSN to mustangfu Send a message via Yahoo to mustangfu
The power windows in the 94-95 mustangs have a tendency to go out because of the rubber bushings. Do you hear the motor moving still? If that's the case, and it's not off track, then you have to take the motor out, take off the cover, and replace the rubber bushings. Here's a better article: http://www.sn95forums.com/forum/index.php?topic=19275.0
It's not cheating when you're sitting in the corner watching and beating your dick like it owes you money
mustangfu is offline
post #4 of 10 Old July 17th, 2008, 06:46 PM Thread Starter
Thanks guys but when i press the button it makes no noise at all no clickin no buzz, nothing. Does that mean i need to just replace the motor for it?
post #5 of 10 Old July 17th, 2008, 09:46 PM
that usually means the motor is either not working or blown. Listen real careful. Go over to the passenger side and hit the button and pit your ear by the panel. Or take the panel off and listen. I'd def check the fuses first. I dint know what one it is but just pull each one out one by one. Check to see if there blown. If they are the metal connection will be separated. Check burt by the pedals and the box under the hood. If there alright its most likely the motor
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
SCT MAF
Tune
03 cobra pumps
HVGC
post #6 of 10 Old July 18th, 2008, 01:18 AM
burnout5.0's Avatar
try hitting the door panel down by the speaker while holding the button down it might just work then. its worked for me before.
burnout5.0 is offline
post #7 of 10 Old July 18th, 2008, 09:13 AM
gotta love the weird little tricks that actually work on cars like that.
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
SCT MAF
Tune
03 cobra pumps
HVGC
post #8 of 10 Old July 18th, 2008, 10:01 AM
FaStStAnG5-0's Avatar
Send a message via AIM to FaStStAnG5-0
i put my money on the window motor being bad... i have replaced 4 in my mustang... it's pretty easy to do.
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
FaStStAnG5-0 is offline
post #9 of 10 Old July 19th, 2008, 05:30 PM
I just had the exact same problem...I replaced the switch and now its working like a champ.....
ret27m is offline
post #10 of 10 Old July 22nd, 2008, 11:13 AM
95StangMX's Avatar
if I am not mistaken they should have relays also .... google and find out the correct one and check it also...
95StangMX is offline
Human Verification
