1994 GT
harmonic balance
hey guys i got the puller and i took the pulley off..i could only get two of the bolts threaded in, out of the four holes because of the way the puller is shaped..i screwed in the center bolt and when i try to tighten it, it just spins the crank. Is there a bolt in the middle where the center bolt screws into? or does anyone have any ideas on how to keep it from spinning?
Cohagan Engineering, Inc. |
You only need two bolts on the puller. There is a big bolt in the center of the balancer. If you don't remove that the balancer will never come off.
1994 GT
thanks for the help.
1994 Mustang GT
also you can put the car in gear and have some one hold the brake and that will hold the crank, thats what I had to do
That isn't going to do anything when the balancer bolt is still in the crank....
1994 Mustang GT
hmm, guess I didnt read the question well enough, sorry
Threads Similar to: harmonic balance
| Our Account Balance | Trance | The Clubhouse | 16 | April 17th, 2008 05:59 PM |
| 28oz Balance | 95StangMX | 5.0 Mustangs | 19 | January 16th, 2008 09:24 PM |
| Chemistry... Can Someone Balance This Equation For Me? | Triple A | The Clubhouse | 10 | November 13th, 2007 05:47 PM |
| harmonic balance | mustang1072 | V6 Mustangs | 13 | February 17th, 2007 04:09 PM |
| underdrive and engine balance | thewayshemoves | 99-04 | 7 | December 3rd, 2006 01:50 PM |
