Engine harness swap question.
Old July 29th, 2008, 03:57 PM   #1
Superarnie is on a distinguished road
Smile
This is a question for all my 'across the pond' friends!
I have a 94-95 5.0 project engine which I hope to drop into my AC Cobra kit car when completed. So far so good. However, I had no engine electrical components at all and therefore went and bought a brand new Ford Racing engine/injector harness, ECU harness etc, thinking, erroneously, it would be compatible with my engine. It appears at the very least that the distibutor connections are different and also the TPS connection? I don't have Air Conditioning pump or Power steering pump, just a simple engine set up.
Can anybody who has a good knowledge of all things electrical, give me their advice on how I could adapt what I have to make it fit?
Many thanks
Gary (Sunny England, UK)
Old July 29th, 2008, 04:18 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
If you are using a fox (87-93) dizzy then I can see your problem, the harness from a 94-95 is different than the Fox body components. What year are the motor components from and what year harness did you purchase? Also what ecu are you going to be using?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old July 29th, 2008, 04:21 PM   #3
1994 Mustang GT
mustang1994bob is on a distinguished road
I believe it is posible, but look at this option>
Painless PERFECT Engine Management System - Ford 5.0L (94-95)
also there is alot of good info on 5.0 efi here>
Ford Fuel Injection
they also have a huge selection of pigtails and other custom wiring parts to make things work
Old July 31st, 2008, 01:37 PM   #4
Thanks guys for your help and advise.
I have all the 94-95 ancillaries, ie; throttle body/elbow, IAC and TPS, so the distributor is also a 94-95 item.
Unfortunately I have realised that the Ford Racing 3 part harness I bought was a 89-93 year production harness and some of the connectors aren't compatible with the components on my engine.
I wondered if there was a way round it?
The Painless harness appears to be good, however it doesn't appear to be heat wrapped and I have already paid alot of money for the Ford items I have.
All advise appreciated!
Regards
Gary
Old July 31st, 2008, 03:48 PM   #5
95opal's Avatar
95 opalfrost gt
Try e-bay for a sn 95 harness you should be able to find one fairly cheap.
5.0 magazines
Old August 6th, 2008, 11:10 PM   #6
xelitexjamx's Avatar
2006 mustang v6
xelitexjamx is on a distinguished road
Send a message via AIM to xelitexjamx
find the old connecters... cut off the new ones.. wire in the old connectors on the new harness... simple as that...
Threads Similar to: Engine harness swap question.
wiring harness swap? FoxHoss 5.0 Mustangs 8 October 27th, 2007 04:05 AM
engine wiring harness and ecu help wilkie22 5.0 Mustangs 9 September 5th, 2007 07:26 PM
Another Dumb Engine Swap Question OcOnnor220 99-04 8 July 31st, 2007 03:00 PM
Engine harness and computer man_of_war2081 99-04 5 April 28th, 2007 10:21 PM
