Engine shakes
Old August 3rd, 2008, 11:38 PM   #1
1995 Mustang GT
N/A
Colt45bennett is on a distinguished road
Send a message via MSN to Colt45bennett
Exclamation
Engine shakes
my car is shaking bad when im in park and and has a bad acceleration and cuts a lil when going up hills
Old August 4th, 2008, 12:58 AM   #2
1995 Mustang GT
N/A
o and i forgot that my rpm needle is bouncing when idling
Old August 4th, 2008, 07:27 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like an ignition related misfire. What exactly is causing it will take some time. If it hasn't had a tune up in a while then I would start there.
Old August 5th, 2008, 10:09 PM   #4
94 cobra
96gtponyred is on a distinguished road
seafoam the sh!t out of it, its a good start. i had the same problem on my 96 and seafoam worked wonders
cobra R hood (has a vin#)
bassani catback flows welded in
jegs O/R H-pipe
Jlt CAI
Mgw shifter
03 cobra rims
3.73's (on the way!!!)
Old August 6th, 2008, 10:57 PM   #5
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i'd say that honestly it's something to do with the plugs especially if the idle seems to smooth out if ya bring it up just a little bit. But then again sometimes these things are hard to diagnose over the internet
Old August 7th, 2008, 08:46 AM   #6
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
does the engine run better when you give it WOT? if it stays rough or bogs when you are wide open, then its probably your MAF...
Old August 8th, 2008, 02:08 AM   #7
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
More than likely it's the stator inside your dizzy, they crap out on our cars if there's 80k+ miles on it. What kind of shape is your balancer in? If there's rubber coming out of it, time to replace it. Point being, if you end up replacing the dizzy you'll never get an accurate timing reading with a bad balancer.
See garage for mods
Threads Similar to: Engine shakes
First the shakes, now it wants to melt down! Jaguar 94-95 2 July 5th, 2007 07:27 PM
Hood shakes? Vettefast 2005 - 2010 16 May 4th, 2007 04:41 PM
tire shakes! help please NinjaStallion V6 Mustangs 11 March 1st, 2007 02:57 PM
My GT Vs. STOCK Focus -shakes head- thewayshemoves 99-04 20 November 28th, 2006 11:23 AM
car shakes at 75 95StangSVT 5.0 Mustangs 3 November 22nd, 2006 11:34 AM
