Clutch Problem
Old August 16th, 2008, 09:28 PM   #1
1994 Mustang GT
all5.0motor is on a distinguished road
Clutch Problem
A couple weeks ago i was drivin my 94gt and i noticed my cluch would squeak every once in a while when i pushed it in. Then tonight while i was drivin a few times i stoped at a red light i was not able to put my shifter in to 1st gear all the way once i started to move the shifter would then move all the way in. I have no idea what could be wrong with my tranny im not good with trannys at all so some help on what is wrong and what to do would be great.
Old August 17th, 2008, 12:40 PM   #2
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
if you are not getting the shifter all the way in, then your clutch may not be disengaging completely. check your clutch cable and make sure its not getting hung up on anything
Old August 17th, 2008, 10:22 PM   #3
94BLKGT is on a distinguished road
Might be a bent clutch fork. It also could be a bad throwout bearing.
Old August 17th, 2008, 11:01 PM   #4
95BlackStang's Avatar
2000 mustang GT
95BlackStang will become famous soon enough
most likely its the throw out. mine has the same problem
00 GT with the heart of a green machine!
99 Electric Green GT R.I.P.
95 GT vert....my first love sold!
Originally Posted by BaznastyDave View Post
99-01 Cobra bumper with Mach spoiler and make all the girls panties wet.
Old August 20th, 2008, 01:57 PM   #5
1994 Mustang GT
im not havein the problem with putting it in gear all the way now i changed my trany fluid but the clutch still squeeks a little when i push it in could that be the TOB
Old August 20th, 2008, 02:08 PM   #6
Ryno8705's Avatar
Ryno8705 is on a distinguished road
If you hear squeeking when your clutch pedal is up and NOT when it's down = Throw out bearing. If not then your TOB is probably fine. If you have the factory adjustment system, make sure your clutch is fully adjusted and see if it makes a difference.
From what you said I bet you have a bad syncro on 1st. If you put it in 1st rolling at under 5 mph and it feels like it's missing the gear that is a sign of a syncro going bad. (if you don't feel it yet I'm sure you will soon.) It could also be a bent clutch fork. I had the same deal with my 94 GT
Threads Similar to: Clutch Problem
Possible clutch problem? Please help!! 96DropTop 96-98 3 August 3rd, 2008 12:30 AM
Clutch problem? Odin 2005 - 2010 23 June 24th, 2008 02:50 PM
clutch problem! saltydog_NM 5.0 Mustangs 7 May 20th, 2008 04:49 PM
clutch problem rob madison 96-98 5 October 26th, 2007 10:06 AM
problem with clutch. mike96gt 96-98 2 September 21st, 2007 03:33 PM
