lowest springs?
Old August 22nd, 2008, 11:33 AM   #1
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
lowest springs?
right now i have ford motorsports "c" springs, but I want to get my car as low as I can. i really like the Steeda sport springs, and that's what I want to get, but I don't think those are the lowest out there... any ideas on what might be the lowest spring i can get? thanks
Old August 22nd, 2008, 06:43 PM   #2
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
id prob say check out eibach, they have some low springs, a good way to get drop is to take the stock isolaters out if you havent yet, and if its still not low enough for ya you can cut half a coil out and it will drop it considerably. I see you have the c/c plates which is good as dropping a car to much without those adjusted can lead to bad alignment, excessive tire wear etc, if you dont wanna cut your springs go check out eibachs site, or H&Rs there good to
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old August 22nd, 2008, 06:50 PM   #3
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
cut the springs
www.moddedmustangs.com
Old August 22nd, 2008, 07:07 PM   #4
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
cutting the springs is an option but not the smartest it could result in your car riding like absolute garbage. i have the eibach pros in my car and the drop is much more noticeable than the ford racing c springs that i had in my last 95 stang.
Old August 22nd, 2008, 07:13 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
yeah check into eibachs sportline springs, they have a 2" drop and people have been taking the spring isolators out to get it a that much lower
Old August 22nd, 2008, 07:13 PM   #6
Lind's Avatar
when you cut the spring measure and make sure you do the same for each heat and bend the ends alittle so they lay alittle flat ter
Old August 22nd, 2008, 08:15 PM   #7
WildWill's Avatar
1995 Mustang GT
well, i wont cut the springs, but the eibachs sound good... what exactly is the spring isolator?? how do i take it out?
Old August 22nd, 2008, 08:36 PM   #8
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
the spring isolators are the pieces of rubber on the top and bottom of the spring to eliminate road noise. when you change springs they will come out.
Old August 22nd, 2008, 09:04 PM   #9
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
My car on Eibach Sportlines
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old August 23rd, 2008, 02:05 PM   #10
WildWill's Avatar
1995 Mustang GT
thanks adder... that's what im looking for.
when you take the isolators out, is the road noise a lot worse? im not too worried about it, but if it is a significant increase in road noise, then i probably wont do it
Old August 24th, 2008, 12:47 AM   #11
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
mine are Hyperco. i think they are more of a road racing spring than a lowering spring. they sit pretty low, they arent as smooth as the eibachs but the car corners like it's on rails. personally i'd go with the eibachs.
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old August 24th, 2008, 11:11 AM   #12
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
Originally Posted by Lind View Post
cut the springs
do not cut the springs! its stupid
Cohagan Engineering, Inc.
Old August 24th, 2008, 11:12 AM   #13
TKOTLARZ's Avatar
1994 GT
i have eibach's and its really low
Old August 24th, 2008, 11:37 AM   #14
91 mustang lx coupe
way too slow
thatdavidkid is on a distinguished road
Send a message via AIM to thatdavidkid Send a message via Yahoo to thatdavidkid
cutting springs is only an option in my oppinion if you have constant rate springs... gt springs are NOT constant rate... mach 1 springs are though... sport lines with isolators removed are probably your best bet.. it wont be THAT bad with road noise.. also, if you're going that low, be sure to buy either a bump steer kit or at least offset steering rack bushings, because it will get "jerky" over bumps in the road because you offset the steering rack from the steering knuckle so much...
Old August 24th, 2008, 12:32 PM   #15
95BlackStang's Avatar
2000 mustang GT
95BlackStang will become famous soon enough
eibachs are the way to go
00 GT with the heart of a green machine!
99 Electric Green GT R.I.P.
95 GT vert....my first love sold!
Originally Posted by BaznastyDave View Post
99-01 Cobra bumper with Mach spoiler and make all the girls panties wet.
Old August 24th, 2008, 12:34 PM   #16
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
my car is kinda low.
It's a free mod to.
Old August 24th, 2008, 12:39 PM   #17
2000 mustang GT
hahaha that sucks
Old August 24th, 2008, 04:34 PM   #18
WildWill's Avatar
1995 Mustang GT
ummm.... ok. lol. that's hilarious. i think i'll keep my wheels on. looks like im gonna get eibachs
Old August 24th, 2008, 09:06 PM   #19
2000 mustang GT
you wont regret it
Old August 26th, 2008, 12:15 PM   #20
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
i got some maxspeed lowering springs on my cobra...and eibachs on my gt....both are awesome....
Threads Similar to: lowest springs?
Drag springs or lowering springs??? AggieStang General Tech 10 February 18th, 2012 12:45 PM
2006 mustang gt lowest whipple price for 500 hp intercooled black H.O. kit navyman8903 2005 - 2010 4 March 23rd, 2008 07:34 PM
whats the lowest tsp_2177 2005 - 2010 12 February 5th, 2008 12:32 AM
Lowest Price on Flowmasters? wormster00 2005 - 2010 20 November 20th, 2007 02:43 AM
Are v8 front springs noticeably different vs. 4 cyl. springs 90hatch 5.0 Mustangs 3 August 8th, 2006 06:23 PM
