1994 GT
11.75@120
check engine light
I have a 94 GT basically stock just 2 steps colder on the plugs(for the zex 100 shot) and an offroad x-pipe. So today on my way to school i was in fifth gear at around 1500 rpms going up a hill and my check engine light went on. shortly after going down the hill it went off. the car doesnt seem to have a low rpm misfire or anything but could it possibly be the o2 sensor is just reading the car at full rich or something??? just kinda curious what you guys have to say.
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot |
mine does the same thing, but I know i have a bad cat thats screwing up my o2, so your on the right track thinking its you o2 sending the check engine code.
If only superchargers grew on tree's |
1995 Mustang GT
have your computer run for codes... if something is tripping or has tripped you will find out
1994 Mustang GT
Same thing as lowp51 happens to me. +1 on the o2 sensor reading rich
![]() 1994 Mustang GT stock 5.0L K&N Fliter Hurst Pistol Grip Shifter Rear Seat Delete Euro Tail Lights Flowtech O/R H-pipe Flowmaster Glasspacks '99 GT Rims |
97GT & 97Snake & 00L
T.B.A
well u have off road x...off course ur check engine light is gonna be on...
Why do you have 2 step colder plugs? Just curious....
1995 Mustang GT
2002BLGT is right, they won't throw a code with an off road x or h pipe. However I do believe the 02 sensors will - that'd be the first thing I'd check out. Or like someone else mentioned, plug it in and see if the scanner picks anything up.
1994 GT
11.75@120
yea 94-95 the o2 sensor is in front of where the cat would be. it reads the mixture before the cat not after like 96 and up. and thanks for the response guys ill def have the codes read.
1994 GT
11.75@120
because when you run the dry shot of nitrous it will lean the car out therefor causing a hotter spark. so to keep it from getting super lean/hot ZEX recommends going with colder plugs
T.B.A
#12 | |
I just had to ask because every so often I see people post that they have colder plugs and they are only running a small amount of nitrous. I never understood why...
#13 | |
1994 GT
11.75@120
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot Last edited by smott; September 15th, 2008 at 12:23 AM. |
No a dry system does not lean the engine out. The term "Dry system" doesn't mean no fuel is introduced to the system. Additional fuel is most definitely added to the mixture when using a dry system but its not added with the nitrous mixture, hence the term "Dry". If no additional fuel was added there would be no horsepower gain. It seems that you need to study nitrous systems a bit more because you definitely do not understand a dry system or how it works.
1994 GT
11.75@120
No i understand how the systems works, but i was taking it as if you were saying fuel was added with the nitrous. I do know that a dry systems works by increasing the fuel pressure to the injectors which in turn does add more fuel. And i dont see the need to get offensive because i was not trying to insult you i was just reading what u said differently. And i know from expierence that you can lean out your motor because i have blown up a 5.0 from running a 125hp dry shot but the fuel pump didnt keep up and ended up blowing the motor.
#16 | |
As far as the engine blowing up, yes nitrous causes an extreme lean condition when there is no fuel like I mentioned in a previous post. Your fuel pumped failed and wrecked your engine, the dry nitrous kit had nothing to do with it.
Threads Similar to: check engine light
| check engine light | gwilkrrs | 99-04 | 1 | June 8th, 2008 07:27 AM |
| Check Engine Light On... | Racerchik02 | V6 Mustangs | 34 | November 30th, 2007 12:27 PM |
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 05:03 PM |
| check engine light... | ponykid8703 | V6 Mustangs | 12 | January 22nd, 2007 07:03 PM |
| Check Engine Light? | GreenFaleen | V6 Mustangs | 13 | November 20th, 2006 02:26 AM |
