LinkBack (1) | Thread Tools |
#1
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Starting a Build up Any suggestions with my setup
okay so i have a 95 GT. Stock from the stock air box. to the stock tail pipes. here is what i'm looking into getting...basically putting together a wish list. My job is offering alot of overtime right now and i'm due for a pretty good bonus in a month or so. So i'm looking to do this in about 6 months.
306 Bottom End BBK CAI Grantelli MAF BBK 75mm TB TrickFlow Upper and Lower TrickFlow Heads forced induction Cam of some sort BBK LT's BBK Catted X Bassani Catback 4.10's 150 Shot of Nitrous until i can save the money for a Kenne Bell or D1SC i'm looking to be able to make somewhere in the 550-600 HP range do ya think that'd get me there...or anything else i should replace in the setup?? |
I'd use a stock bottom end. Spend that money on the SCT Pro Racer Package so you can have someone tune the stock ineffiecencies out of the computer.
1995 Mustang GT
someone in another thread said that my block wouldn't hold...and are those HP numbers reasonable??
#4 | |
The block will fail before the crank, rods or pistons will. 530 is probably a more reasonable number.
1995 Mustang GT
so you think the block will support around 500 RWHP
The block might hold 500rwhp but you aren't going to make that much at the wheels with only 150hp of nitrous. At the flywheel, yes. At the tire, no. Maybe with a blower but not with the combination you listed and 150hp of nitrous.
1995 Mustang GT
so in other words, your stock block will be fine. i know guys that run mid 10's in the 1/4 with a stock 302 bottom end.
+1 on investing in a quality tune, whether you take it to a tuner or get it done yourself.
1994 Ford Mustang GT
how easy are those tuning programs to use, like air/fuel ratio can you control all of that and do it easy, like tell the computer to back off the gas when you start reaching certain rpms because i run bad rich at 4200 :/ and what one would you guys recommend, a buddy was trying to get me to spend $1200 on a AEM 1
www.moddedmustangs.com |
95 mustang gt
this is just my opinion (ive never had these heads)...but...ive heard the trickflows arent reliable...ive heard of a guy at the track that took a hammer to those and couple more times people have had problems with them they do make great horsepower but idk i never had them so i cant say much
other than that your setup sounds beastly! id go with afr heads and go with the stock bottomend and get a tune on the dyno then youd be set!
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
#10 | |
1994 GT
Cohagan Engineering, Inc. |
1995 Mustang GT
what kind of times do you run on your set up???
#12 | |
2000 mustang GT
#14 | |
PeteAndersonRacing.com |
#15 | |
1995 Mustang GT
i've got trick flow twisted wedge aluminums on mine, and they're badass. darrell is right, trick flow are some of the best performing heads out there. definitely spend the money on a tune, or your car just won't run the way it should. another mistake i made was not upgrading the fuel pump...throw in a bigger one, put in an adjustable fuel pressure regulator, and probably bump up the size of your injectors if they are stock. golden rule, you've got to let it eat!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/89903-starting-build-up-any-suggestions-my-setup.html
| Starting a Build up Any suggestions with my setup | This thread | Refback | September 23rd, 2008 09:00 AM | |
Threads Similar to: Starting a Build up Any suggestions with my setup
| The Build Is Starting | Doc8224 | 4V / SVT | 40 | April 17th, 2008 10:27 AM |
| Starting the Build Pics. Inside | 05mustang_TT_charged | 2005 - 2010 | 239 | April 12th, 2008 12:35 AM |
| Starting my 306 engine build | shurb125 | 5.0 Mustangs | 48 | February 9th, 2008 01:41 PM |
| gaming pc build suggestions | whiteboycustom | The Clubhouse | 34 | February 7th, 2008 08:39 PM |
| any suggestions on this setup would help | Iownastang | 5.0 Mustangs | 8 | May 26th, 2007 09:09 AM |
