Subframes and Control Arms
Old September 28th, 2008, 02:59 PM   #1
too slow
95blackbeauty is on a distinguished road
Send a message via AIM to 95blackbeauty
Where is the best place to get these? reasonably priced...is the install difficult? The subframes are weld in correct? I cant put my power down on the track...and im getting sticky tires and i needed some suspension mods...is there anything else i can do?
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
BOOSTED
Old September 28th, 2008, 03:54 PM   #2
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
get the full length square subframe connectors and some people bolt them in but definitely weld them like u said..i got my control arms from UPR..doing those two things will make a huge improvement..stiffer springs will help to
Cohagan Engineering, Inc.
Old October 2nd, 2008, 02:56 AM   #3
94 cobra
96gtponyred is on a distinguished road
which is better upper or lower control arms or both ??
cobra R hood (has a vin#)
bassani catback flows welded in
jegs O/R H-pipe
Jlt CAI
Mgw shifter
03 cobra rims
3.73's (on the way!!!)
Old October 2nd, 2008, 02:57 PM   #4
TKOTLARZ's Avatar
1994 GT
yea i would buy the set
Old October 2nd, 2008, 04:21 PM   #5
fairlane_68 will become famous soon enough
Fully welded in connectors are the way to go, square tube with support braces seem to work best and offer the least flex. I've always made mine, if you can weld and use a torch, it's the cheaper route. And try moving your battery to the trunk...helps with the weight transfer.
Best to replace/upgrade them as a set. That way you KNOW what shape their in.
Old October 7th, 2008, 02:06 AM   #6
BadBlack95GT's Avatar
1995 Mustang GT
BadBlack95GT is on a distinguished road
Send a message via Yahoo to BadBlack95GT
You really only need lower control arms unless you're really tuning the suspension... you need that little bit of flex they offer, if you go with an U/L adjustable ok, but even then, you need to know how to tune the suspension to get the most out of it... check out UMI's control arms for the Mustang... they got a lot for the GN, but they make GREAT products...
agree with everyone else on the SFC Full length square with corss braces. Maximum motorsports sells a good set
Old October 8th, 2008, 02:07 PM   #7
too slow
so go with the full length and not the regular ones?
BOOSTED
Threads Similar to: Subframes and Control Arms
control arms SilverGT04 99-04 7 March 5th, 2008 01:30 PM
QA1 Tubular Control Arms (A-Arms) keith0s 5.0 Mustangs 3 October 19th, 2007 11:20 AM
steel control arms vs aluminum control arms Saleenwolf720 99-04 1 October 15th, 2007 01:32 PM
Upper Control Arms & Lower Control Arms LUV2XLR8 2005 - 2010 6 October 6th, 2007 11:45 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005 - 2010 6 July 4th, 2007 04:59 PM
