95' gt upgrades
Old October 3rd, 2008, 10:09 AM   #1
1995 mustang gt
usmc95gt is on a distinguished road
95' gt upgrades
i have a 95' gt i am working on. so far i have a cai, full exhuast. next i plan on 3.73 gears, trickflow top end kit, throttle body, udp's and msd ignition. does that sound like a good setup? should i upgrade anything else? and what do i do about tuning it with all of the new parts? i appreciate any info you can give me.
Old October 3rd, 2008, 09:24 PM   #2
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
Trickflow kit is excellent , dont forget the ELBOW for the throttle body since you have a SN95
Old October 3rd, 2008, 11:10 PM   #3
bretts95gt's Avatar
95 mustang gt
bretts95gt will become famous soon enough
do you have a 5spd? or auto? go 4.10s if you got a auto you should start upgradeing your fuel system too. start with injectors id say about a 30 if your getin heads cam intake
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Old October 4th, 2008, 12:30 AM   #4
1995 mustang gt
i got a 5 speed. and yes im getting heads cam and intake. also if i go with bigger injectors what kind of fuel pump should i go with?
Old October 4th, 2008, 12:53 AM   #5
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
dont start with injectors..go with a 255 fuel pump and a regulator..then add some subframe connectors and rear control arms..u can make power but u need to get it to the ground
Cohagan Engineering, Inc.
Old October 4th, 2008, 04:06 AM   #6
1995 mustang gt
i plan on installing sub connectors and contol arms as well. but with the heads cam and intake you think the stock injectors will be able to keep up? also what kind of pressure should i set the regulator at? i have about 8k$ to put into the car for now so im trying to go the best route with it. thanks for the info and if you have any other tips im all ears.
Old October 4th, 2008, 04:11 AM   #7
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
that top end kit, 30# injectors, 255 fuel pump, lower/upper control arms and a tune and u should be good to go
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old October 4th, 2008, 01:51 PM   #8
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Sounds like a good plan but I suggest you keep the stock ignition and save the money that you would have spent on the MSD ignition for other things. If you're going to get the TFS top end kit and keep the engine naturally-aspirated, you'll need the following to finish the engine upgrades:
70mm TB (75mm also good)
TFS throttle body elbow
76mm MAF
24lb injectors (keep stock regulator)
Higher-flow fuel pump (190lph is good)
Computer reprogramming (Tweecer RT best value for money)0
Since you have a manual tranny, stick with the 3.73 gear but add the following to help get the power down:
Welded-on subframe connectors
Upgrade rear lower control arms (I recommend Maximum Motorsports)
You can add more handling upgrades as your budget allows.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old October 4th, 2008, 04:57 PM   #9
1995 mustang gt
cool thanks man. on the maf i read a thread about them and now im confused do i get one cal. to 19# or 24# since the comp is getting reprogrammed?
Old October 4th, 2008, 05:53 PM   #10
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
if your getting 24# injectors, get it calibrated for 24's.
Old October 5th, 2008, 03:38 AM   #11
Bullitt95's Avatar
13.546 @ 105.32
x2
Old October 8th, 2008, 04:43 AM   #12
BadBlack95GT's Avatar
1995 Mustang GT
BadBlack95GT is on a distinguished road
Send a message via Yahoo to BadBlack95GT
24# injectors are good to 350hp, i doubt you'll be above that with a top end kit... UMI Performance Inc. also makes good suspension components... don't let the GN on the home page scare you away. my setup...
MMR tubular K-member, Tubular A-arms, front coilovers(175lb springs), Maximum motorsports full length subframes with cross braces, UMI(I also like racecraft) Lower control arms. leave the stock uppers, with a stiffer lower, you'll need the deflection. Eibach drag springs, solid suspension set up. can't do anything without a solid suspension... I've got 3.90 gears in mine.(95 5spd GT) puts me in my power band at the perfect time. course all that is setup for drag racing...
Old October 8th, 2008, 01:14 PM   #13
1995 mustang gt
thanks for the link some good stuff on there
Old October 8th, 2008, 01:49 PM   #14
BB Service is on a distinguished road
What are you ultimate goals for the car?
For instance, if you plan on going forced induction down the road, get the injectors, fuel pump and MAF now that will take you there. There's no need to waste money on parts that will need changing again in the future. Keep in mind that you don't want to be doing things twice. I learned the hard way
Threads Similar to: 95' gt upgrades
95' gt bigtom 5.0 Mustangs 24 May 27th, 2008 12:19 AM
My 95' GT-S 5.0wned 5.0 Mustangs 1 May 25th, 2008 12:52 AM
OBD II in a 95' Snipe061 V6 Mustangs 4 March 28th, 2007 10:21 AM
Chips for a 3.8L 95' V6 Snipe061 Audio/Video 4 March 23rd, 2007 04:01 PM
