94 Mustang GT
cold air intake
ok heres whast i got. a 90mm maf from a lighting and a C&L air intake. the maf is to big for the rubber tube to connect the maf and the air intake. i was wanting to know what to do?
1995 Mustang GT
why exactly do you have a 90mm MAF? i'm thinkin thats too big man.
94 Mustang GT
i was told that when i had it tuned that the maf was max out and i need to go with a bigger one.
95 Mustang GT
what the HELL is your combo? and what injectors are you running cause you need to make sure and match the MAF with the injectors
![]() People should think about boarding up their glass house before starting a rock fight! |
i hope you got a lot of cubes, or some type of forced induction if you're running a 90mm MAF.
as far as your question goes... I know here locally we have a speed shop that sells rubber hoses with step up, and step down sizes. depending on what you need... i would say check your local speed shops. |
94 Mustang GT
all i have is a tf street heat upper kit, headers, 30lb, injecters, msd ignition, flow masters, x-pipe, bbk throttle body and spacer, tremmec tko. i want get it stroked or supercharger but that down the road.
1995 Mustang GT
You're fine with the LMAF. I've never heard of hooking one up to a C&L though. You might want to look into an Anderson ford motorsports N/A powerpipe. Are you putting the MAF in the fenderwell?
To the rest of you, the LMAF isn't too big and he doesn't need alot of cubes or forced induction. It can be tuned to use with 30, 36, 42, etc injectors and is by far the cheapest MAF on the market @ only 90 bucks.
See garage for mods |
#8 | |
94 Mustang GT
![]() Join Date: Oct 2008
LMAF = Lightning MAF
The Anderson Ford Motorsports N/A Powerpipe flamedstang95 is referring to places the MAF in the fenderwell allowing for cooler air to be pulled into the motor rather than having the MAF pull air from inside the engine bay. What are you currently using to connect your MAF to the throttle body? The easiest thing to do in your case is get a coupler that reduces from the size of the MAF to the size of the intake pipe you're using. |
1995 Mustang GT
all he means by LMAF is 'lightning mass air flow"
and i'm not sure (correct me if i'm wrong), but i think he's asking whether you are mounting the actual MAF unit in the fenderwell or not. he might also just mean a fenderwell cold air kit, where the filter goes into the fender sucking in cooler air than the kits that have the filter in the actual engine bay. |
1995 Mustang GT
haha, looks like bbservice got his post in right before me
his makes more sense anyways!+1 |
94 Mustang GT
thanks guys for helping out. it all makes sense now. i think i might try to put the LMAF on the C&L. if that doesnt work i will probable just start over and go with the anderson.
1995 Mustang GT
If you're looking for couplers then check out Intake Hoses, IntakeTubing, and Intake Clamps or go to your local Home Depot/Lowes, I'm sure they'll have something.
You guys were both right, I meant that putting the LMAF in the fenderwell with the filter hooked to it. It will keep things much cooler.
thats still a big ass MAF... for whatever reason i was thinking 90mm TB. *smacks head*
Threads Similar to: cold air intake
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
| cold air intake | 1BADSTANG | 5.0 Mustangs | 11 | June 5th, 2008 02:28 PM |
| Cold Air intake | 06GT300 | 2005 - 2010 | 15 | April 27th, 2008 02:08 PM |
| cold air intake | jrock | 99-04 | 19 | November 25th, 2007 01:45 AM |
| Ram Air Shaker System vs. Cold Air Intake | scxc15 | V6 Mustangs | 9 | January 28th, 2007 01:22 PM |
