Idleing too high
I have a 95 gts and the idle won't go down below 1500 I unpluged the iac and it runs perfect. Does this mean it's bad or could it be the tps?
2003 Black Cobra. Steggy stg 3 port, 2.76/4lb, JLT CAI, Dragon t/b, 60s, BAP, Mafia, sct SF3, Afco H/E, MAC LTs w/ORX-pipe, Borla stingers, MM FLSCs, MM cc plates, Billetflow IRS brace, Eibachs, 315 Toyo R888, 18in bullits. 526/506 7.8 1.9 60ft 92mph |
1994 GT
take ur IAC off and keep the electrical plugged in..have somone turn the key on and look at the IAC it should open and close as u turn the key on for sure..but if it does that doesnt mean its not the problem still..
Cohagan Engineering, Inc. |
1995 Mustang GT
more than likely the IAC.
Well I plugged up the iac with the tps unplugged and the idle went from 500 to like 800, and it runs so much better. So I think it's the tps now because when I plug it up then the idle jumps to bout' 1500, so I left it unplugged. Is this ok?
#5 | |
2000 mustang GT
1995 Mustang GT
well it is very likely that both will have to be replaced at some point, so you might as well start by replacing the IAC, if that fixes your problem, so be it, if it doesn't, look at the tps.
1994 GT
replace them both..it'll make a hell of a difference..you'll be very happy..i know the IAC is alot more than the TPS
1995 Mustang GT
You can probably replace them both for a little under 100 bucks. They're 13 y/o parts, they're not going to perform like they did when new.
See garage for mods |
Unplugging a sensor and the car running differently doesn't mean it is bad. There are many things that can cause your problem. A bad mass airflow sensor, vacuum leak, ignition timing, IAC are just some of the possibilities. The first thing to do would be to scan the computer whether you have a check engine light on or not. The next thing to do would be to check for vacuum leaks.
Well I don't have a check engine on, maybe it don't work? I don't know I'll just take it and scan the computer and see what happens.
The check engine light doesn't always stay on when you have codes stored in the computer.
prob. fixed bad tps
It still acts up and idles a little high like 1200rpm. I has a lot more POWER omg so I unplugged my iac and it runs good. I think I'm gonna have to replace it too. In an eariler reply it was said that if I take the iac off my car, leave it plugged up, then turn my key on it should open. Well I did that and all that happen was a click it didn't really move. Does this mean it's bad?
#14 | |
1994 GT
Threads Similar to: Idleing too high
| car is hesitating while idleing | 20gtvert03 | 99-04 | 0 | June 25th, 2008 01:06 AM |
| update on idleing probs - still doing it | M0T0PSYC0 | 99-04 | 8 | May 18th, 2008 02:49 AM |
| idleing problems still | M0T0PSYC0 | 99-04 | 6 | May 16th, 2008 02:15 PM |
| Problems (Idleing) and Accelerating) | Darkside_03_GT | 99-04 | 10 | December 19th, 2007 07:34 AM |
| 89 LX Idleing Funny Please Help | Steves LX | 5.0 Mustangs | 4 | December 28th, 2006 06:29 PM |
