Forest Green 1994 GT
Steering Wheel Play
HEy all,
My car is running awesome.. But there is a small amount of play in my steering.. i'd say around 1/8 of an inch either way, its not much but its enough on windy days to have we appear drunk LOL.. I have checked my front wheels.. and there level. as well I check for extra play and there nice and tite. Any other ideas what this could be..? Thanks DOn |
1994 GT
check the small "u joint" type joint in the steering column..also check the rack bushing, i kno i have play because the rack bushing are shot
Cohagan Engineering, Inc. |
#3 | |
How hard are these to replace? DO I need to remove my steering column? Don EDIT: I bet its cause of the 245's on the front.. that wore it out? |
1994 Mustang GT
I have a 94Gt and had the same problem but I had like 2" play. I looked under the hood at the steering input shaft that goes from the steering column down to the rack. It's below the brake booster and next to the headers on the drivers side. I found that there is a joint just above the u-joint where one shaft goes inside another. The joint is covered by a black plastic nut. My nut was dry rotted and the inside shaft was not tight inside the outer, so that left me the play. I just got a long drill bit and drilled the two pieces and put a 3/8" bolt through them both to keep them from moving until I can get a new input shaft. Works great and fixed the problem.
Hope that helps!! |
95 opalfrost gt
Most likely a worn rag joint in the shaft.
Thanks guys, I will look at it during my lunch tomorrow. I have a buddy that can prob help me replace it over the weekend, This is the same guy who
pulled a whole steering column out of one t-bird to put in another.. fully installed in less then an hour LOL.. ![]() Thanks guys Don |
1995 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() I'm sorry for the thread jack, but that just cracked me up! sorry man! hahaha ok I'm done now.
2000 mustang GT
1995 Mustang GT
99.9% sure it's the rag joint. I had the same exact problem on my last 95. I wouldn't blame anything other than age and header heat. Check out ebay for another one. I found one on there for 20 bucks BRAND NEW just in case the same thing happens to my current 95. Home for your Ford Mustang @ Blue Oval Industries used to sell '03 cobra shafts for around 40 bucks, not sure if they still carry them though.
See garage for mods |
1994 Mustang GT
Yeah, that was kinda funny.............. didn't catch that one before i hit submit......LOL
Threads Similar to: Steering Wheel Play
| steering wheel | brokebp417 | 5.0 Mustangs | 8 | November 10th, 2008 10:34 AM |
| steering wheel | terribleonexx88 | 5.0 Mustangs | 2 | March 17th, 2008 09:33 PM |
| Steering Wheel | Baker02125 | Visual | 20 | December 24th, 2007 04:06 AM |
| New steering wheel | 69fastback | Classic Mustangs | 5 | July 23rd, 2007 01:14 AM |
| Steering wheel | Nick_Rapitis | V6 Mustangs | 6 | May 25th, 2007 05:39 PM |
