1993 GT
Location: From Scottsdale,Arizona living in Scottsboro,Alabama
Pro-M Install Question
I just installed a 75mm on my bone stock 94 and have gone through the usuall resetting of the computer,but after letting it idle for about 10 minutes and then driving it for about 15 it is still stalling when i come to a stop.Could someone enlighten me on the problem or fix for this.I think i might be jumping on the pedal a little to early during the computer relearning phase.
P.S yes it is calibrated for stock 19# injectors |
ya mught whata clean your IAC. might be the problem ,might not. but wouldnt hurt to clean it .............
Go Tarheel's, your our men, if you can't do it!!!............................................. ...............................DAMN!!?? |
did you get any gains out of doing that, I'm thinking about doing it to but with putting 24 pound injectors on it, how do you set the comp to run right with the both of them. I heard all that will just make my car run rich any input
ProM isnt exactly known for thier quaity.
Also curious as to why you put a larger MAF on a stock engine... The stock MAF flows more than enough for most all bolt on mods.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
#5 | |
Especialy with the sn95 ecu.
1993 GT
ok well i just bought the maf for a future setup and i was just trying it out,but i didnt think it would have idle issues.Doesn't the computer compensate for the extra incoming airflow by richening up the mixture?
and adjusting idle? ill try to clean the iac and see what happens.and i agree the stock maf is good up to a certain point. thanks for the replies.
1994 GT.......SOLD!!! 1993 Black On Black GT |
Threads Similar to: Pro-M Install Question
| T5 install question | wolverine8490 | 94-95 | 1 | July 27th, 2007 11:55 AM |
| X pipe install question HELP PLZ | Blue98GT | Modular Mustangs | 7 | June 5th, 2007 07:18 PM |
| h-pipe install question... | James | 99-04 | 2 | February 22nd, 2007 02:56 PM |
| V6 Cam install question | 02ponypackage | V6 Mustangs | 6 | February 14th, 2007 02:20 PM |
| Steeda Tri Ax Install Question | o3gtdgs | 99-04 | 4 | November 15th, 2006 11:22 AM |
