deleted egr now running ruff?????
Old October 29th, 2008, 09:08 PM   #1
1994 mustang gt
1fast5.0 is on a distinguished road
Send a message via AIM to 1fast5.0
what do i need to do after deleting egr im in the process of switching to a carb but im waiting on some money for the manifold and i need to know how to get it to run semi right please help
Old October 29th, 2008, 09:23 PM   #2
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
is it pinging? or will it just not run?
Old October 30th, 2008, 02:26 PM   #3
1994 mustang gt
there is no pinging but it studders like it not gettin enough gas and after sitting still the idle start surging
Old October 30th, 2008, 04:06 PM   #4
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
So, what did you do with the vacuum lines going to the EGR valve? I think there is a red one and green one(can't remember) They should run to your valve, under your upper intake and to other lines on the passenger side. If you haven't gotten rid of them, do it or at least cap them off. I deleted my EGR and didn't have any of the problems you are having, I also deleted it in the tune.
See garage for mods
Old October 30th, 2008, 04:42 PM   #5
1994 mustang gt
i have all lines caped that should be it just feels really sluggish since i removed it and i deleted my smog so i dunno it want be a problem in a couple of months when i through the carb on it it will be a pure beast the efi is way to much trouble to deal with and the computer i need none of it i want a pure motor no electornical tuning and thats what i will have soon enough
Old October 30th, 2008, 06:20 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
LOL! Yeah, a carb will really wake her up. That's some funny shit right there.
Why did you "delete" your EGR? It didn't help your performance at all (obviously). The obvious solution is to "undelete" it.
Old October 30th, 2008, 07:28 PM   #7
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Are you still running a catted h-pipe? Deleteing the EGR does absolutely nothing as far as performance. The only reason peeps do it is to clean up the bay a little.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old October 30th, 2008, 09:46 PM   #8
1994 mustang gt
i didnt delete the egr for performance reasons i deleted the smog and ac for that reason and no i have true duals into super 44s into dumps and you tell me the carb wont help tell me why drag cars run carbs instead of efi
Old October 30th, 2008, 09:48 PM   #9
1994 mustang gt
and the egr has alot to do with the comp and it is miss reading for some reason if you would read and observe u would understand what i said
Old October 30th, 2008, 10:58 PM   #10
95opal's Avatar
95 opalfrost gt
If you knew so much about the EGR and its workings then you would understand that your surging idle is a direct result of you removing it without turning its function of in the ECM. Until you do so you may never get rid of the surge.
You may have luck by adding a resistor to try and trick the ECM, but that is still just a bandaide.
5.0 magazines
Old October 31st, 2008, 06:00 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I don't know how often you get out, but alot of race cars run EFI.
Old October 31st, 2008, 11:00 PM   #12
WildWill's Avatar
1995 Mustang GT
+1 you need to get it switched off in the computer otherwise the car will never run right. i've heard dealerships can do it for like $100, but don't quote me on that. or you can just put the EGR back on and wait till you get the carb and then just pull all that sh** out.
Old November 1st, 2008, 02:36 AM   #13
1995 Mustang GT
The only way he's going to go back to using it is to go back to EFI. He has nothing there for it to bolt to. Take it to a tuner and get it turned off.
See garage for mods
Old November 1st, 2008, 11:37 PM   #14
WildWill's Avatar
1995 Mustang GT
oh i didn't think he had switched to carb yet... but +1
Old January 26th, 2009, 10:28 PM   #15
1995svtcobra's Avatar
95 SVT Cobra
1995svtcobra is on a distinguished road
http://www.rjminjectiontech.com/ will have the plug you need to trick the computer, they also have plates and caps for egr deleted sys.
70 mm Eldelbrock MAFS,K&N,King Cobra Clutch,EGR Delete,Off road H Pipe,BBK chrome shortys,Dynomax Mufflers
Old January 27th, 2009, 12:22 PM   #16
Trick Tuners's Avatar
KB'd GT
I agree. EFI is FAR superior to carbs, especially for street cars. Carbs are ok on race cars because they don't care about idle quality, part throttle drivability, and retuning for weather and elevation changes.
EGR is off at idle. It can cause part throttle surging, especially with wild cams. I would look for an air leak, or exhaust leak.
Old January 28th, 2009, 10:54 AM   #17
95StangMX's Avatar
95 Mustang GT
I dont think drag cars care about driving the car for more than 6 seconds and to them smelling like gasonline is cool.......what made you decide to go carb anyways? Are you manual or auto trans?
Old February 26th, 2009, 12:50 AM   #18
95GTSTALLION's Avatar
1995 Mustang GT Vert
95GTSTALLION is on a distinguished road
You would think that deleting the EGR would have a positive performance effect since there wouldn't be that extremely hot exhaust gas back into the Intake Manifold... But I could be wrong?
Old February 26th, 2009, 11:15 AM   #19
KB'd GT
No performance gain because its off at wot.
EGR explained - Trick Tuners Forums
Threads Similar to: deleted egr now running ruff?????
those who deleted egr adrenaline=lifeline 99-04 31 November 1st, 2008 11:08 PM
Ruff Ride imported_Gt_Jay 5.0 Mustangs 2 November 13th, 2007 08:53 PM
loss of power//ruff idle and engine shut down.// no start dj hexadron 99-04 1 July 25th, 2007 12:41 AM
ruff price 01stanggt Modular Mustangs 3 June 4th, 2007 06:37 AM
