#21 |
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
my BBK o/r H-pipe has no cats (obviously, which means less restrictive air flow), is larger in diameter (which also means less restrictive air flow), and it was noticeabley lighter than the stock h-pipe
it's a win win win situation
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
#22 |
1991 mustang 5.0
aftermarket midpipe = 2.5" and not alot of bends for more flow
stock midpipe = 2.25" with alot of bends and 4 cats which makes it more restrictive Don't cut out your cats. Buy an aftermarket midpipe and save your stock one for emmissions. |
#23 |
MSTRB8N & MDR8N
2021 Mustang V15
and like i said, it's really not that hard to swap out h-pipes once you figure out a trick to it.. i honestly think it would be easier to swap midpipes out every year than cutting off your cats up near your headers
#24 |
MSTRB8N & MDR8N
2021 Mustang V15
you will LOVE the sound of the BBK o/r H-pipe with flows.. the tone and volume is perfect.. trust me on this, you will not regret it.. just watch the video i posted.. it will obviously be louder and sound better in person though
#25 |
1991 mustang 5.0
You do post entirely way too much lol
#27 |
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
i love my off road x and flows
#28 |
1995 Mustang GT
slower than a 3 leg dog
#29 |
1994 Mustang GT
I just got a Pypes off road X-pipe with Borla mufflers and honestly think it sounds better then flows. No where near the interior drone of a flowmaster, and a little quieter which i'm happy about because daily driving with a constant buzz gets old.
And X/H pipes don't make the exhaust spin.. It works to give equal pressure across all the cylinders essentially pulling air out of the cylinders and reducing back pressure. Minor torque loss can happen tho, it's not a myth. X-pipes in general give higher hp gains in the top end while sacrificing a little bit down low. H-pipes are better for the bottom end. Ultimately if you want it street able ya have to decide what you want. If you get an off road pipe now you can save a little money now and put in some high flow cats later come inspection time. Which may or may not be cheaper in the long run if you or someone you know can weld. Last edited by Dysfunction; January 16th, 2009 at 04:27 PM. |
#30 |
2007 Mustang V6 pony pack
Get an off road h pipe and 2 1/2 piping duals with gt500kr mufflers that would probably be ur best option IMO keep the cats if u wanna sound deep
#31 |
94 Mustang Gt
my exhaust setup is in my sig below.
I love it at cruising and idle its not so loud that you cant talk to the person next to you but when you step on it you know for sure its a v8. A friend of mine has an offroad h and dumped 40's and the thing is just stupid loud. at idle and cruising and crazy on acceleration
94 Mustang Gt Vert-Mods: Tubular Headers, BBK Catted X, SLP Loudmouth 2's, EGR Delete |
#32 |
My two cents:
I think these cars are slower without Cats. Yes, when you take the cats off you get better flow, but better flow means the 02 sensors arn't getting hot and are not reading right. If you have a sensor not reading correctly it throws everything off, even if it is only slightly.
#33 |
ive got a question... i live overseas so forget about getting a off road x-pipe. Right now i dont have mufflers just the cats, i want to take those 2 out also, but will i have a problem with not having backpressure? If i get some cherrys installed will that help out a little?
#34 |
1995 GT
unless you have a fully built motor pushing over 450HP then yea, your gonna suffer from not having enough backpressure. having the mufflers would help alot.
#35 |
1995 Mustang GT
just get a upr off road-x and be done with it. I have an H now, but much preferred the x that I had on my old 96. Depending on the muffler you go with, it wont be "crazy" loud. I never had an issues with police and I had custom mufflers with only 2 baffles in each. Sounded ba. do it
![]() Aluminum heads, TF upper/lower, bbk tb c&l intake w/Pro*M Racing MAF, shorty headers 24# injectors, off-road H, custom catback H&R springs, 3.73's short throw.....still slow. |
Threads Similar to: Catylic converter VS NO CATS?????
| x pipe... cats, no cats, etc | A5295 | 5.0 Mustangs | 7 | January 18th, 2009 01:49 PM |
| SCT for No cats...But I Have Cats | beefmobile | 2005 - 2010 | 6 | October 23rd, 2008 03:24 PM |
| converter | HTK241 | 99-04 | 7 | October 21st, 2007 01:27 PM |
| converter | lagunas375 | General Tech | 0 | January 24th, 2007 03:16 AM |
| converter | reeds98gt | 96-98 | 9 | June 15th, 2006 04:46 PM |
