full pi swap
Old December 7th, 2008, 11:36 AM   #1
1998 Mustang GT
fliptikal is on a distinguished road
full pi swap
anyone here done a full pi swap on a 98 gt? i'm about to do one. i'm throwin the cms/vt stage II cams with the patriot performance valve springs kit with the titanium retainers into the pi heads first. then im going to rip off the old heads and shit. but anyways i'm just wondering what kinda problems i might run into while doing the swap. if anyone has done a pi head swap + pi manifold swap. please let me know the goods and the bads u run into. thanks
Old December 8th, 2008, 10:42 AM   #2
NottyBoy93's Avatar
1993 Notch, 1988 Notch
NottyBoy93 is on a distinguished road
Let me get this straight, you are going to spend money on the stock heads first, then go with Patriot?
I would save your money, and go for the Patriot heads and ditch the stockers....Unless I am not seeing something here
Old December 8th, 2008, 02:06 PM   #3
1998 Mustang GT
yeah im going with the stock heads..but i am talking about getting the patriot performance valve springs and retainers only...
Old December 8th, 2008, 02:07 PM   #4
1998 Mustang GT
i cant afford to drop 1400$ dollars on patriot heads. that's why i just got the pi heads and pi intake manifold for only 250$
Old December 9th, 2008, 08:03 AM   #5
NottyBoy93's Avatar
I'm just sayin' I would have saved a while. I guess I think a little too old school, but that's what I do, I save until I can by the components I want that fit my application.
Hell I'm 36 with a wife and two kid's and I simply wait until I can get what I want. That I guess was my point. If I buy something just to get me through, then I wind up double buying, I know I'm going to upgrade later if I don't get what I wanted to begin with.
Capice?
Old December 13th, 2008, 12:21 PM   #6
ajm
Im using patriot springs as theyre the only ones I could find easily find that support the amount of lift im running and they seem to be fine.
Old December 17th, 2008, 08:51 PM   #7
LightDude is on a distinguished road
patriot springs are great.. but they're are just too costly i think.. If you have lots of money to burn then go for it..
HID Lights
Old December 17th, 2008, 09:57 PM   #8
ajm
$144 for 16 of them, comps are $200, manley even more
Old December 18th, 2008, 11:49 PM   #9
Stroker281's Avatar
2001 Mustang GT
N/A
Stroker281 is on a distinguished road
I would not even go with Patriot head they sux! Alot of people had bad problems with those heads! The valve guides break and ur valve will bent or cause damage to ur pistons. So den you would have to do a whole rebuild from the bottom up. If I were you jus port and polish them or sent them to get done. I would recommend TAF (Total Air Flow) they do good work. Put if you wanna get some good heas wait until Trick Flow comes out with theres. Its gunna cost thou!
Old December 18th, 2008, 11:55 PM   #10
Garrett's Avatar
1998 Mustang gt
Garrett is infamous around these partsGarrett is infamous around these partsGarrett is infamous around these parts
Send a message via AIM to Garrett
Ive done a full PI swap. I just bought an "04 engine from ford and had a guy put it in for me. So I don't have a problem at all.
myspace.com/garrettstarnes
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
Throtle Body spacer.
More to come!
Threads Similar to: full pi swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
full pi swap fliptikal 96-98 4 December 7th, 2008 04:50 PM
Anyone done a full PI swap themselves? CAcorral 96-98 9 February 2nd, 2008 09:50 AM
02 PI full engine swap into 98 gt nurd 96-98 1 July 1st, 2007 05:07 PM
Full PI head/intake swap or Find new PI motor? 96PonyGT 96-98 7 January 3rd, 2007 08:10 AM
