MM's Ginger
1998 mustang gt
walkable
Need help ASAP!!!!!
Im having big trouble with my headlights not fitting right. What do i need to do?
Are they both the same?
MM's Ginger
1998 mustang gt
walkable
yeah but the other one has a slightly smaller gap, i was thinkin about grinding away some of the car that doesnt show behing the turn signal, cause it looks like thats where its hitting and leaving a gap like that
I wouldn't grind the car. I would ascertain whether or not you got a defective part, and if so, send it back and get a replacement.
MM's Ginger
1998 mustang gt
walkable
yeah thats also a possibility i was thinking about, i got it from american muscle so if it is a bad part, it doesnt look good on them
1997 SVT Cobra
Did the adjuster screws go all the way through their holes? That would keep you from being able to push it all the way back I'm sure.
Here are the instructions I looked at on their site. You may have already seen them but I'm not sure what they're grinding on in the early steps. That could also be a possibility. How To Install Mustang Angel Eye Projector Headlights
MM's Ginger
1998 mustang gt
walkable
thanks but i already seem them, i did push all the rods in except the bottom one wasnt fully in but that isnt gonna fix the gap, i wanted to put them in by tomorrow and getting a different style headlights isnt an option
are you SURE the bottom rod wont effect the gab? dont start grinding on anything. just do more research. why isint a different style an option?
97' GT 98' DSG Cobra |
MM's Ginger
1998 mustang gt
walkable
cause i drilled a hole in my console in front of the hand brake for a special switch just to turn on the rings
97 Mustang GT
slower than the speed of smell
ok that gap is normal for those headlights. dont worry about it. you must dremel out some of the plastic and make sure the headlights are fitting in their spot. (do you understand that?) if its not that then you must fiddle with the posts and angle the headlight at the position you desire and try and get it to work. it will take some time trust me, they are a pain to get perfect. even when they are perfect there might be a little gap or something but it will be more reasonable. just take your time and if you get frustrated just leave and come back to it.
97 Mustang GT
found a picture of my dremeling the plastic.
MM's Ginger
1998 mustang gt
walkable
thanks but i did dremel the plastic out and its not a factor, but wont rain get in between the gap and short out the wires?
Billy Weston
Sure you didn't get the wires pinched behind the headlight?
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
97 Mustang GT
not unless the wires are exposed. there is about as much chance of that as rain shorting out your stock headlights. you can shrink the gap but it takes patience and a little wrestling with the prongs. to be honest i actually took the whole assembly out like 20 times before i was satisfied with both. it is possible to close the gap you just have to mess with it. are both headlights like that? (they both have gaps or only one?)
MM's Ginger
1998 mustang gt
walkable
I removed the posts (all 3) to make it easier to push it in and remove to see where the issue might be. Behind the back edge
of the turn signal area it is hitting (on both sides of the car). This is metal and is part of the car. I tapped this area with a small hammer and it has helped. I may grind this metal section away. This section is preventing the unit from sitting flush in the center. I thought that maybe the car has had some front end damage in the past but the stock lites fit like a glove. Once I can hold it in place by hand and it's flush I wll put the 3 posts back on and allign the lights. There is nothing in the instructions about grinding except for the plastic area as shown in your photo. Thanks for responding. |
97 Mustang GT
ok let me put it this way when i put my headlights in i had the same problem. i readjusted them over and over again until they fit without having to grind any metal off.
MM's Ginger
1998 mustang gt
walkable
so do you still have a gap?
97 Mustang GT
not really, i mean i wish i could show you a picture but unfortunately it is up north. theres like a tiny gap at the bottom of the headlight actually on the drivers side but it doesnt bother me too much and i can hardly notice it. the passenger side is perfect.....at least from what i remember.
97 Mustang GT
![]() ![]() ![]() ![]() ![]() thats what my headlights look like. i hope it helps. |
Threads Similar to: Need help ASAP!!!!!
| need help asap!!!!!!!! | armymike63b | 99-04 | 8 | July 19th, 2008 02:51 PM |
| I Need Help Asap!! | 5.065stang | 5.0 Mustangs | 14 | July 14th, 2008 11:30 AM |
| I Need Help Asap | 04mustang232 | V6 Mustangs | 15 | May 25th, 2008 05:45 PM |
| help asap please | WeCircleTheProblem | V6 Mustangs | 14 | August 16th, 2007 06:21 PM |
| NEED HELP ASAP!! | VetteC5RFrEak | 5.0 Mustangs | 0 | August 3rd, 2006 02:01 AM |
