Discussing Smoke in the 96-98 Forum. I am starting to get some small white smoke when i use the heat. I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Smoke
I am starting to get some small white smoke when i use the heat. I noticed it this morning. However there is no smoke coming from under the hood. I am having some MAF problems with this new intake I got, so im gonna switch it back to the K@N after work. Could this smoking problem be caused from a bad fliter?
lol, nobody knows anything about this ? 15 views / 0 responses. I just opened the hood there is 0 smoke anywhere. im a little low on coolant but not enuff that it would make any diff i dont think my intake howerver is loose as hell im fixin to tighten that up. ANy suggestions?
MM's Coffee Addict
1999 SVT Cobra
I can haz coffee?!
I guess I'm a little confused as to where the "little white smoke" is coming from. Your tailpipes? Through your A/C? Clarify that for me and I'll give you my opinion on what could be happening - oh and I've never heard of an air filter causing smoke anywhere (unless it's over oiled and the excess oil reaches your intake manifold)
MM's Coffee Addict
1999 SVT Cobra
I can haz coffee?!
Oh yeah and what kinda car are we talking about here?
Its a 96 mustang and its coolant coming through the air vents . So far the lady i talked to said it could b something called a heater core. The heat works but its puttin a smell that smells just like coolant out the a/c vents. 96 Mustang GT
the smell from your vents should smell like pancakes or even rotten pussy and it would be your heater core, be prepared for the thing to really blow and fog your windshield up something feirce and leave you stranded.
MM's Coffee Addict
1999 SVT Cobra
I can haz coffee?!
Yeah, probably a heater core problem. If it does burn up you'll know it (mix between a musty wood smell and burning rotted food, lol I know from experience with previous cars) and it sounds like yours is likely on its last life - fortunately a lot of shops offer that kind of repair service for cheap.
If it's not a daily driven car maybe you'd want to get an a/c eliminator kit (underdriven pulleys, etc.) and you wouldn't have to worry about it. But if you're like me you need the a/c in these cold wintery months. Good luck |
Yeh its the heater core, thanks alot guys. One of my friends at work tho said you have to take off the entire dash to get to it so I bet labor on this is gonna be high as hell.
Threads Similar to: Smoke
| Smoke-em | HMUSN | The Clubhouse | 0 | November 9th, 2007 08:54 PM |
| To much smoke | Scrapdaddy SR. | V6 Mustangs | 17 | June 8th, 2007 01:56 AM |
| smoke | coreyfitz | 5.0 Mustangs | 3 | April 14th, 2007 01:26 AM |
| smoke? | therapist | 99-04 | 2 | January 29th, 2007 04:32 PM |
| smoke | WVSNS& | 99-04 | 15 | January 2nd, 2006 04:13 PM |
